StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black
Quicklinx: 9KRFWS00 Mfr#: DP2VGDVHD
27 In Stock
£31.29 ex VAT
£37.54 inc VAT
Connect a DisplayPort-equipped PC or Mac to an HDMI, VGA, or DVI Display. The DP2VGDVHD DisplayPort to VGA, DVI or HDMI converter offers a compact 3-in-1 solution for connecting your DP-equipped desktop, laptop or Ultrabook computer to a VGA, DVI, or HDMI display.
Compatible with almost any display, television or projector, this versatile converter provides the ideal plug-and-play solution for travel or BYOD (Bring Your Own Device) applications around the office. With three of the most common interfaces to choose from, the converter equips you to walk into any boardroom ready to connect to an available display device, even if you don't know what connection ports will be available.
For seamless connections from your DisplayPort-equipped computer, the converter supports video resolutions up to 1920x1200/1080p, so you can convert a DisplayPort video source to VGA, HDMI, or DVI without sacrificing video quality.
The DisplayPort converter offers a small footprint and lightweight design that makes it easy to keep on hand without it taking up too much space in your laptop bag.
  • Connectivity options
    Easily connect your DisplayPort device to multiple displays using HDMI, VGA, or DVI outputs, making the adapter suitable for a variety of setups.
  • High-resolution support
    With a maximum output resolution of 1920 x 1200, this adapter delivers clear and detailed visuals for presentations and media playback.
  • Audio capabilities
    The adapter includes support for 7.1 channel Surround Sound, allowing for an immersive audio experience alongside high-quality video.
  • Plug-and-play convenience
    Set up is simple and quick as the adapter requires no additional drivers or software, ensuring immediate compatibility with your devices.
  • Active cable technology
    Designed with active cable technology, this adapter ensures reliable signal transmission with minimal signal loss, optimizing overall performance.
StarTech.com 3 in 1 DisplayPort Multi Video Adapter Converter - 1080p DP Laptop to HDMI VGA or DVI Monitor or Projector Display (DP2VGDVHD) - adapter - DisplayPort / HDMI / DVI / VGA - 26.6 m
Cable
Adapter - DisplayPort / HDMI / DVI / VGA
Max Output Resolution
1920 x 1200
Length
26.6 m
Connectors
DisplayPort - male
Connectors (Second End)
HDMI - female , HD-15 (VGA) - female , DVI-D - female
DisplayPort 1.2
Active cable, 1920 x 1200 (WUXGA) support
3-year warranty
Cable Type
Adapter active, 1920 x 1200 (WUXGA) support
Interface Supported
DisplayPort 1.2
Length
26.6 m
Adapters & Converters
1920 x 1200
Connectors
20 pin DisplayPort - male
19 pin HDMI Type A - female , 15 pin HD D-Sub (HD-15) - female , 24+1 pin digital DVI - female
Plug and Play, FCC, RoHS
4.5 cm
2 cm
65 g
Shipping Width
20 cm
Shipping Depth
22 cm
Shipping Height
1.7 cm
Shipping Weight
73 g
Limited warranty - 3 years
9KRF StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £8.51
9KRF StarTech.com DisplayPort to DVI Active Adapter In Stock £20.81
9KRF StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter In Stock £20.15
9KRF StarTech.com Mini DisplayPort to HDMI Video Adapter Converter - White In Stock £9.27
9KRF StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.35
9KRF StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.03
9KRF StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter In Stock £7.58
9KRF StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £15.11
9KRF StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black In Stock £31.29
9KRF StarTech.com Travel A/V Adapter: 3-in-1 Mini DisplayPort to VGA DVI or HDMI In Stock £8.96
9KRF StarTech.com mDP to HDMI or VGA Converter In Stock £8.19
9KRF StarTech.com USB C Multiport Video Adapter with HDMI, VGA, Mini DisplayPort or DVI, USB Type C Monitor Adapter to HDMI 1.4 or mDP 1.2 (4K), VGA or DVI (1080p), Silver Aluminum Adapter - 4-in-1 USB-C Converter (CDPVGDVHDMDP) - adapter - Mini DisplayPort / HDMI / DVI / VGA - 10.5 cm In Stock £22.46
9KRF StarTech.com DisplayPort to HDMI - 4K 60Hz In Stock £21.78
