StarTech.com DisplayPort DVI Video Adapter Converter
Quicklinx: 68KQWS00 Mfr#: DP2DVIADAP
Connect your DVI monitor to a DisplayPort equipped computer. The StarTech.com DP2DVIADAP DisplayPort DVI adapter lets you connect a DVI-D display to a DisplayPort video source (e.g. DisplayPort video cards, etc.), eliminating the expense of having to upgrade to a DisplayPort enabled display while providing a hassle-free connection to any DisplayPort video card/signal source.
The DVI/DisplayPort adapter supports display resolutions up to 1920x1200, allowing you to take full advantage of single link DVI capability.
DP2DVIADAP is a passive adapter that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
StarTech.com DisplayPort DVI Video Adapter Converter - DisplayPort to DVI Converter - DP to DVI - DisplayPort to DVI Adapter (DP2DVIADAP) - DisplayPort adapter
DisplayPort adapter - single link
Connector
DisplayPort - male
Connector (Second End)
DVI-D - female
FCC, RoHS
3-year warranty
P/N: DVIDDMM1, DVIDDMM10M, DVIDDMM25, DVIDDMM2M, DVIDDMM3M, DVIDDMM5M
DisplayPort adapter
TMDS Links
Single link
Connector
20 pin DisplayPort - male
24+1 pin digital DVI - female
FCC, RoHS
3-year warranty
68KQ StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £11.80
68KQ StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £21.80
68KQ StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M In Stock £22.37
68KQ StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £16.94
68KQ StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £9.22
68KQ StarTech.com 6 ft DisplayPort to DVI Cable - M/M In Stock £5.53
68KQ StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F In Stock £8.02
68KQ StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £8.38
68KQ StarTech.com DisplayPort to DVI Active Adapter In Stock £21.34
68KQ StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 In Stock £41.39
