StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F
Quicklinx: 76LPWS00 Mfr#: DP2MDPMF6IN
Type: DisplayPort
Length: 15.2cm
£8.26 ex VAT
£9.91 inc VAT
The DP2MDPMF6IN DisplayPort to Mini DisplayPort Adapter turns a mini DisplayPort (male) connector into a regular DisplayPort (male) connector, making it easy to connect a mini DisplayPort-equipped monitor to a laptop that only provides a standard DisplayPort output (e.g. Apple, Toshiba etc.).
StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter (DP2MDPMF6IN) - DisplayPort adapter - 15.2 cm
DisplayPort adapter
Molded
Length
15.2 cm
Connector
DisplayPort - male
Connector (Second End)
Mini DisplayPort - female
RoHS
P/N: SV231DPU, SV231DPUA
DisplayPort adapter
Shielding Material
PVC
American Wire Gauge (AWG)
32
Molded
Length
15.2 cm
Connector
20 pin DisplayPort - male
DisplayPort 1.2, RoHS
76LP StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £11.58
76LP StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F In Stock £10.50
76LP StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £21.26
76LP StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £20.51
76LP StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.00
76LP StarTech.com Mini DisplayPort to DVI Video Adapter Converter In Stock £9.55
76LP StarTech.com Mini DisplayPort to HDMI Video Adapter Converter In Stock £10.66
76LP StarTech.com 3ft DisplayPort Panel Mount Cable - F/M In Stock £14.45
76LP StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F In Stock £8.26
76LP StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £8.18
76LP StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F In Stock £8.20
76LP StarTech.com 2m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £10.55
76LP StarTech.com 1m (3 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £3.73
76LP StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £11.66
Type: DisplayPort
Length: 15.2cm
