StarTech.com Desk Mount Monitor Arm-For up to 30" Monitors-Articulating
Quicklinx: FF5BWS00 Mfr#: ARMPIVOTB2
Save space with this premium desk-mount monitor arm, by suspending your display above your desk. It supports a monitor up to 30", with an articulating arm that makes it easy to adjust your screen.
Use the single monitor desk mount to mount your VESA mount monitor (75x75, 100x100) up to 30". You can also mount your Apple Cinema Display, 24-inch iMac or 27-inch iMac, or Thunderbolt Display that came with a removable stand or built-in VESA mount adapter. The attractive silver finish complements Apple displays, making it ideal for customer-facing workstations.
Made of aluminum, the heavy-duty monitor arm provides stable support for your display, with a weight capacity of up to 30.9 lb. (14 kg).
The arm extends 8.3" (210 mm) to allow a wide range of motion. Move the monitor arm effortlessly side to side to adjust your screen position.
With its articulating arm, the monitor mount makes it easy to find the right viewing angle. Pan a full +180/-180 degrees left or right and tilt your display +90/-15 degrees to adjust the angle up or down. For landscape or portrait viewing, rotate your display 360 degrees.
Work in comfort. This height adjustable computer monitor arm lets you raise or lower the monitor arm along the pole, with a range of up to 7.87" (200 mm).
Quick slide-and-click connections ensure easy assembly and save time when setting up multiple units. The computer screen mount gives you the option of desk-clamp or grommet-hole mounting. Hardware is included for all mounting options.
StarTech.com Desk Mount Monitor Arm, VESA or Apple iMac/Thunderbolt Display up to 14kg, Articulating Height Adjustable Single Desktop Monitor Pole Mount, Desk Clamp or Grommet, Silver - Small Footprint Design (ARMPIVOTB2) mounting kit - adjustable arm - for Monitor - TAA Compliant
Mounting kit (adjustable arm) - desk-mountable
32 cm x 32 cm x 52 cm
Tilt
-15° to 90°
Pan
-180° to 180°
Lift
20 cm
Rotation
360°
Adjustments
Height, pan, tilt, rotation
2.5 kg
Recommended Use
Monitor
Recommended Display Size
49"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
14 kg
Material
Steel
TAA Compliant
Package Content
Hex key (4mm), hex key (3mm), 2 x mounting screws, 4 x screws, swivel arm, 4 x surface protectors, flange mount, access card
5-year warranty
32 cm
32 cm
52 cm
2.5 kg
Material
Steel
Package Content
AV Furniture
Mounting kit
Design
Adjustable arm
Recommended Use
Monitor
Placing / Mounting
Desk-mountable
49"
Tilt
-15° to 90°
Pan
-180° to 180°
Lift
20 cm
Rotation
360°
Adjustments
Max Load Weight
14 kg
TAA Compliant
Dimensions & Weight Details
23 cm x 47 cm x 14.5 cm / 3.24 kg
Limited warranty - 5 years
FF5B StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 In Stock £69.47
FF5B StarTech.com Thin Client Mount - VESA In Stock £23.19
FF5B StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £51.28
FF5B StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £58.71
FF5B StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £75.65
FF5B StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop In Stock £7.60
