StarTech.com Desk Mount Quad Monitor Arm
Quicklinx: CRY0WS00 Mfr#: ARMQUAD
Accessory Type: Mount
£178.29 ex VAT
£213.94 inc VAT
Mount four monitors to your desk to maximize productivity and save space. Free up valuable space by mounting four monitors on one base, to suspend your monitors above the surface of your desk, workstation or table. This sturdy desk-mount quad-monitor arm is constructed of heavy-duty steel and will hold all four displays securely in place to create an impressive and productive workspace.
Create the ultimate workstation by mounting four monitors on one base that attaches securely to your desk, table or other surface. You can view multiple screens at the same time to work more efficiently while freeing up space.
The quad-monitor arm offers enhanced productivity in numerous office and commercial applications, such as banking and finance, letting you compare documents and analyze data more effectively. It's also ideal for software developers, programmers, CAD designers, and many other professionals. You can also create engaging digital signage displays to communicate with your clients or employees.
With its heavy-duty solid steel construction, the quad-monitor mount securely holds your monitors and helps to ensure long-lasting performance. Each monitor arm supports a flat-panel display from 13" to 27" (330 to 686 mm) in size and up to 17.6 lb. (8 kg) in weight.
You can adjust the position and angle of your monitors for comfortable viewing, with +30° to -30° swivel and tilt. The quad-monitor mount enables smooth and effortless tilting, which makes it easy to reduce glare and find the ideal viewing angle. For precise alignment, the monitor arm offers micro adjustments that enable you to perfectly line up your displays.
The monitor mount supports four VESA mount compliant monitors and it's easy to install using the desk clamp or grommet mount. To keep your cables neatly tucked away, the quad-monitor arm features cable management clips that help to keep your workstation tidy.
  • Versatile mounting options
    Featuring a desk-mountable design, the monitor arm can easily be secured to various desk surfaces, providing flexibility in installation and allowing users to maximize their workspace.
  • Extensive range of motion
    With tilt adjustments of -30° to 30°, pan adjustments of -30° to 30°, and full 360° rotation, this arm allows for personalized positioning, enhancing comfort and productivity.
  • Robust construction
    Constructed from heavy-duty steel, the monitor arm is built to support up to 8 kg per monitor, ensuring stability and longevity even under heavy usage.
  • Efficient cable management
    An integrated cable management system helps to keep cords organized and prevents clutter, contributing to a neat and professional workspace.
  • Complete package included
    The mounting kit comes with all necessary hardware such as VESA monitor mounts, washers, screws, cable management clips, and clamps, making installation straightforward and convenient.
Startech Desk Mount Quad Monitor Arm, Ergonomic VESA 4 Monitor Mount 2x2 up to 27", Articulating & Height Adjustable Pole Mount, Tilt/Swivel/Rotate LCD/LED Screen, Clamp/Grommet - Heavy-duty VESA Mount (ARMQUAD) mounting kit - adjustable arm - for 4 monitors
Mounting kit (adjustable arm) - desk-mountable
Tilt
-30° to 30°
Pan
-30° to 30°
Rotation
360°
Adjustments
Pan, tilt, swivel, rotation
Recommended Use
4 monitors
Recommended Display Size
13"-27"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Heavy duty steel
Package Content
4 x cable management clips, 16 x washers, hex key (3mm), hex key (5mm), 16 x M4x14 screws, 16 x M5x14 screws, 5 x rubber pads, 4 x thumbscrews, desk clamp, 4 x end caps, 4 x VESA monitor mounts, grommet collar, grommet plate
5-year warranty
Material
Heavy duty steel
Package Content
AV Furniture
Mounting kit
Design
Adjustable arm
Recommended Use
4 monitors
Placing / Mounting
Desk-mountable
Cable Management
Integrated cable management
13"-27"
Tilt
-30° to 30°
Pan
-30° to 30°
Rotation
360°
Adjustments
Max Load Weight
8 kg
Limited warranty - 5 years
CRY0 StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £139.14
CRY0 StarTech.com Dual Monitor Mount - Stackable In Stock £217.58
CRY0 StarTech.com Triple-Monitor Arm - Steel In Stock £144.45
CRY0 StarTech.com Thin Client Mount - VESA In Stock £23.04
CRY0 StarTech.com Quad Monitor Mount - Premium - For up to 27" VESA Monitors In Stock £395.70
CRY0 StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £54.54
CRY0 StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £61.12
CRY0 StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £77.54
CRY0 StarTech.com Six-Monitor Desk Mount/Max 32" In Stock £277.24
