Save space with this premium desk-mount monitor arm, by suspending your display above your desk. It supports a monitor up to 30", with an articulating arm that makes it easy to adjust your screen.
Use the single monitor desk mount to mount your VESA mount monitor (75x75, 100x100) up to 30". You can also mount your Apple Cinema Display, 24-inch iMac or 27-inch iMac, or Thunderbolt Display that came with a removable stand or built-in VESA mount adapter. The attractive silver finish complements Apple displays, making it ideal for customer-facing workstations.
Made of aluminum, the heavy-duty monitor arm provides stable support for your display, with a weight capacity of up to 30.9 lb. (14 kg).
The arm extends 8.3" (210 mm) to allow a wide range of motion. Move the monitor arm effortlessly side to side to adjust your screen position.
With its articulating arm, the monitor mount makes it easy to find the right viewing angle. Pan a full +180/-180 degrees left or right and tilt your display +90/-15 degrees to adjust the angle up or down. For landscape or portrait viewing, rotate your display 360 degrees.
Work in comfort. This height adjustable computer monitor arm lets you raise or lower the monitor arm along the pole, with a range of up to 7.87" (200 mm).
Quick slide-and-click connections ensure easy assembly and save time when setting up multiple units. The computer screen mount gives you the option of desk-clamp or grommet-hole mounting. Hardware is included for all mounting options.
- StarTech.com Desk Mount Monitor Arm, VESA or Apple iMac/Thunderbolt Display up to 14kg, Articulating Height Adjustable Single Desktop Monitor Pole Mount, Desk Clamp or Grommet, Silver - Small Footprint Design (ARMPIVOTB2) mounting kit - adjustable arm - for Monitor - TAA Compliant
- Product Type
- Mounting kit (adjustable arm) - desk-mountable
- 32 cm x 32 cm x 52 cm
- Tilt
- -15° to 90°
- Pan
- -180° to 180°
- Lift
- 20 cm
- Rotation
- 360°
- Adjustments
- Height, pan, tilt, rotation
- 2.5 kg
- Recommended Use
- Monitor
- Recommended Display Size
- 49"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 14 kg
- Material
- Steel
- TAA Compliant
- Package Content
- Hex key (4mm), hex key (3mm), 2 x mounting screws, 4 x screws, swivel arm, 4 x surface protectors, flange mount, access card
- 5-year warranty
- 32 cm
- 32 cm
- 52 cm
- 2.5 kg
- Material
- Steel
- Package Content
AV Furniture
- Mounting kit
- Design
- Adjustable arm
- Recommended Use
- Monitor
- Placing / Mounting
- Desk-mountable
- 49"
- Tilt
- -15° to 90°
- Pan
- -180° to 180°
- Lift
- 20 cm
- Rotation
- 360°
- Adjustments
- Max Load Weight
- 14 kg
- TAA Compliant
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 23 cm x 47 cm x 14.5 cm / 3.24 kg
- Limited warranty - 5 years
StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 | In Stock | £70.33 |
StarTech.com Thin Client Mount - VESA | In Stock | £23.04 |
StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy | In Stock | £54.54 |
StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £61.12 |
StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £77.54 |
StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop | In Stock | £7.52 |
