StarTech.com Desk Mount Monitor Arm - Full Motion - Articulating - Heavy
Quicklinx: FSHTWS00 Mfr#: ARMPIVOTHDB
Accessory Type: Mount
£98.87 ex VAT
£118.64 inc VAT
Free up space while creating an ergonomic work environment. This desk-mount monitor arm makes it easy to securely mount your display above your desk or table and adjust the height with one touch. You can mount a display ranging in size from 13" to 34", and the monitor arm features an attractive black finish that complements your workspace.
This heavy-duty monitor arm saves space on your work surface by elevating your monitor above your desk or table.
The monitor-mount arm features a gas-spring cylinder that makes it easy to raise or lower your display, with up to 13.1" (335 mm) of height adjustment. Adjust the tension according to the weight of your monitor, to re-position the monitor height effortlessly.
The full-motion articulating monitor arm extends up to 23.8" (605 mm) so it's easy to find the right viewing angle. Swivel your monitor 180 degrees to share your display, while collaborating with others. Tilt your screen 90 degrees for comfortable viewing or rotate it 180 degrees for landscape or portrait viewing.
The VESA monitor mount is easy to install (desk C-clamp or grommet mount) and offers built-in cable management. The detachable VESA panel makes it simple to attach or remove your monitor.
  • Ergonomic design
    The adjustable arm allows users to position their monitors at an ideal height, promoting better posture and reducing strain during extended use.
  • High load capacity
    Able to support displays weighing up to 9 kg, this monitor arm is suitable for a wide range of LCD screens.
  • Versatile adjustments
    With pan and tilt adjustments, users can easily find their desired viewing angle, enhancing comfort and productivity.
  • Integrated cable management
    This feature keeps cables organized and out of sight, contributing to a neater workspace.
  • Robust mounting options
    The desk-mountable design provides flexibility for various workspace layouts while maintaining stability and strength.
StarTech.com Desk Mount Monitor Arm, Heavy Duty Ergonomic VESA Monitor Arm, Single Display up to 9kg, Full Motion, Height Adjustable, Articulating, Aluminum, C-Clamp/Grommet, Black - Small Footprint Design (ARMPIVOTHDB) mounting kit - adjustable arm - for LCD display - black
Mounting kit (adjustable arm) - desk-mountable
28.4 cm x 9.6 cm x 52.9 cm
Pan
180°
Lift
17 - 50.5 cm
Rotation
-90° to 90°
Adjustments
Pan, tilt
3.1 kg
Recommended Use
LCD display
Recommended Display Size
13.1"-32"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
9 kg
Material
Heavy duty aluminium
P/N: MONPROTECT
28.4 cm
9.6 cm
52.9 cm
3.1 kg
Material
AV Furniture
Mounting kit
Design
Adjustable arm
Recommended Use
LCD display
Placing / Mounting
Desk-mountable
Cable Management
13.1"-32"
Pan
180°
Lift
17 - 50.5 cm
Rotation
-90° to 90°
Adjustments
Pan, tilt
Max Load Weight
9 kg
Details
Gas spring lift
Dimensions & Weight Details
4.3 kg
P/N: MONPROTECT
FSHT StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 In Stock £70.33
FSHT StarTech.com Thin Client Mount - VESA In Stock £23.04
FSHT StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £54.54
FSHT StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £61.12
FSHT StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £77.54
FSHT StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop In Stock £7.52
FSHT StarTech.com Monitor Desk Mount, VESA In Stock £113.36
FSHT StarTech.com Monitor Desk Mount, VESA In Stock £98.41
