The Monitor Desk Mount for 49" Ultrawide Curved Screen by StarTech.com enhances your workspace by providing an adjustable solution for up to 49-inch displays. Constructed from a combination of plastic, aluminum, and steel, this sturdy mounting kit features a mechanical spring arm for easy adjustments. The integrated cable management system keeps cords tidy, eliminating clutter and distractions in your workspace. With a range of motion that includes pans of up to 180°, tilts from -20° to 50°, and rotations of 360°, customizing your display position to suit any viewing preference is effortless. Designed with versatility in mind, the mount includes both a C-clamp and grommet mount for secure installation on various desk types. It supports a maximum load of 20 kg and is compatible with standard VESA mount interfaces of 100 x 100 mm and 75 x 75 mm. The adjustment options allow for height, depth, pivot, and swivel adjustments to create an ergonomic setup that promotes productivity and comfort, making this monitor mount an essential addition to any workspace.
Versatile mounting options
The Monitor Desk Mount includes both C-clamp and grommet mounting options, providing flexibility for various desk setups and ensuring a stable installation. -
Extensive adjustability
With height adjustments, tilt angles from -20° to 50°, and swivel capabilities of -90° to 90°, users can personalize their monitor position for optimal comfort and productivity. -
Robust construction
Crafted from durable plastic, aluminum, and steel, this monitor mount is designed to support a weight of up to 20 kg, ensuring safety and stability for large displays. -
Seamless cable management
The integrated cable management system helps maintain a clean workspace by organizing cables and wires, enhancing the overall aesthetic of your setup. -
Wide compatibility
Compatible with VESA mounts of 100 x 100 mm and 75 x 75 mm, this mount easily fits a variety of LCD and curved LCD screens.
- StarTech.com Monitor Desk Mount For 49" Ultrawide Curved Screen, Max 44lb mounting kit - adjustable arm with mechanical spring - for LCD display/ curved LCD display - black
- Product Type
- Mounting kit (adjustable arm with mechanical spring) - desk-mountable
- Mounting Components
- Spring arm, swivel arm, base, VESA mount, C-clamp mount 10-80 mm, grommet mount 10-35 mm
- 66.3 cm x 13.4 cm x 62.5 cm
- Adjustable Depth
- 29.3-62.1 cm
- Adjustable Height
- 23.2-50.8 cm
- Tilt
- -20° to 50°
- Pan
- 180°
- Rotation
- 360°
- Swivel
- -90° to 90°
- Adjustments
- Height, tilt, swivel, pivot, rotation, pan, depth
- 4.9 kg
- Recommended Use
- LCD display/ curved LCD display
- Recommended Display Size
- Up to 49" (ultra-wide)
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 20 kg
- Material
- Aluminium, steel, plastic
- Black
- Package Content
- 2 x desk clamp discs, 2 x desk clamp screws, VESA mount nut, 2 x washers (small), 2 x M4 x 10 mm screw, 4 x M6 x 12 mm screws, M8 x 35 mm screw, hex key with screwdriver (4mm), hex key (6mm), 4 x M4 x 12 mm screws, 4 x M5 x 12 mm screws, 4 x washers (large)
- 5-year warranty
- 66.3 cm
- 13.4 cm
- 62.5 cm
- Adjustable Depth
- 29.3-62.1 cm
- Adjustable Height
- 23.2-50.8 cm
- 4.9 kg
- Material
- Black
- Package Content
AV Furniture
- Mounting kit
- Design
- Adjustable arm with mechanical spring
- Recommended Use
- Placing / Mounting
- Desk-mountable
- Cable Management
- Integrated cable management
- Tilt
- -20° to 50°
- Pan
- 180°
- Rotation
- 360°
- Swivel
- -90° to 90°
- Adjustments
- Max Load Weight
- 20 kg
- Details
- Portrait orientation, landscape orientation
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 44 cm x 18.6 cm x 13 cm / 5.5 kg
- Limited warranty - 5 years
StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £77.01 |
StarTech.com 24" Monitor Privacy Screen | In Stock | £79.81 |
StarTech.com 27" Monitor Privacy Screen | In Stock | £101.53 |
StarTech.com 25" Monitor Privacy Screen | In Stock | £71.41 |
