Free up space while creating an ergonomic work environment. This desk-mount monitor arm makes it easy to securely mount your display above your desk or table and adjust the height with one touch. You can mount a display ranging in size from 13" to 34", and the monitor arm features an attractive black finish that complements your workspace.
This heavy-duty monitor arm saves space on your work surface by elevating your monitor above your desk or table.
The monitor-mount arm features a gas-spring cylinder that makes it easy to raise or lower your display, with up to 13.1" (335 mm) of height adjustment. Adjust the tension according to the weight of your monitor, to re-position the monitor height effortlessly.
The full-motion articulating monitor arm extends up to 23.8" (605 mm) so it's easy to find the right viewing angle. Swivel your monitor 180 degrees to share your display, while collaborating with others. Tilt your screen 90 degrees for comfortable viewing or rotate it 180 degrees for landscape or portrait viewing.
The VESA monitor mount is easy to install (desk C-clamp or grommet mount) and offers built-in cable management. The detachable VESA panel makes it simple to attach or remove your monitor.
Ergonomic design
The adjustable arm allows users to position their monitors at an ideal height, promoting better posture and reducing strain during extended use. -
High load capacity
Able to support displays weighing up to 9 kg, this monitor arm is suitable for a wide range of LCD screens. -
Versatile adjustments
With pan and tilt adjustments, users can easily find their desired viewing angle, enhancing comfort and productivity. -
Integrated cable management
This feature keeps cables organized and out of sight, contributing to a neater workspace. -
Robust mounting options
The desk-mountable design provides flexibility for various workspace layouts while maintaining stability and strength.
- StarTech.com Desk Mount Monitor Arm, Heavy Duty Ergonomic VESA Monitor Arm, Single Display up to 9kg, Full Motion, Height Adjustable, Articulating, Aluminum, C-Clamp/Grommet, Black - Small Footprint Design (ARMPIVOTHDB) mounting kit - adjustable arm - for LCD display - black
- Product Type
- Mounting kit (adjustable arm) - desk-mountable
- 28.4 cm x 9.6 cm x 52.9 cm
- Pan
- 180°
- Lift
- 17 - 50.5 cm
- Rotation
- -90° to 90°
- Adjustments
- Pan, tilt
- 3.1 kg
- Recommended Use
- LCD display
- Recommended Display Size
- 13.1"-32"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 9 kg
- Material
- Heavy duty aluminium
- Black
- 2-year warranty
- Designed For
- P/N: MONPROTECT
- 28.4 cm
- 9.6 cm
- 52.9 cm
- 3.1 kg
- Material
- Black
AV Furniture
- Mounting kit
- Design
- Adjustable arm
- Recommended Use
- LCD display
- Placing / Mounting
- Desk-mountable
- Cable Management
- Integrated cable management
- 13.1"-32"
- Pan
- 180°
- Lift
- 17 - 50.5 cm
- Rotation
- -90° to 90°
- Adjustments
- Pan, tilt
- Max Load Weight
- 9 kg
- Details
- Gas spring lift
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 4.3 kg
- Limited warranty - 2 years
- Designed For
- P/N: MONPROTECT
StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 | In Stock | £71.69 |
StarTech.com Thin Client Mount - VESA | In Stock | £23.04 |
StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy | In Stock | £54.54 |
StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £61.12 |
StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £78.75 |
StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop | In Stock | £8.96 |
StarTech.com Monitor Desk Mount, VESA | In Stock | £116.13 |
StarTech.com Monitor Desk Mount, VESA | In Stock | £100.81 |
