StarTech.com Desk Mount Monitor Arm - Articulating - 2x USB 3.0 - Premium
Quicklinx: FW6RWS00 Mfr#: ARMPIVOT2USB3
Accessory Type: Mount
28 In Stock
£92.72 ex VAT
£111.26 inc VAT
Save space with this premium desk mount monitor arm, by suspending your screen above your desk.
  • Sleek and stable design
    Made of aluminum, the VESA mount monitor stand provides stable support for your display, with a weight capacity of up to 8 kg. Built-in USB 3.0 ports provide convenient connectivity for your computer.
  • Height adjustment
    Work in comfort with this height adjustable monitor stand that lets you raise or lower the monitor arm along the pole, up to 24.4" (620 mm).
StarTech.com Desk Mount Monitor Arm with 2x USB 3.0 ports, Pole Mount Full Motion Single Arm Monitor Mount up to 17.6lbs/8kg VESA Display, Ergonomic Articulating Monitor Arm, Clamp/Grommet - Small Footprint Design (ARMPIVOT2USB3) mounting kit - for Monitor - black
Mounting kit - desk-mountable
Mounting Components
Articulating arm, desk clamp mount, grommet clamp
Integrated Devices
2-ports USB 3.0 hub
35 cm x 59.4 cm x 62 cm
Tilt
-90° to 90°
Rotation
-90° to 90°
Swivel
-90° to 90°
Adjustments
Height, tilt, swivel, rotation
3.25 kg
Recommended Use
Monitor
Recommended Display Size
17"-34"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Heavy duty aluminium
Package Content
4 x M4x12 screws, 4 x washers, 4 x M5x12 screws, hex key (3mm), grommet plate, hex key (6mm), cable management clip, grommet screw
35 cm
59.4 cm
62 cm
3.25 kg
Material
Package Content
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Monitor
Placing / Mounting
Desk-mountable
Integrated Devices
2-ports USB 3.0 hub
Cable Management
Integrated cable management
17"-34"
Tilt
-90° to 90°
Rotation
-90° to 90°
Swivel
-90° to 90°
Adjustments
Max Load Weight
8 kg
Dimensions & Weight Details
43.5 cm x 24 cm x 11.7 cm / 4.15 kg
FW6R StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 In Stock £71.48
FW6R StarTech.com Thin Client Mount - VESA In Stock £23.19
FW6R StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £51.28
FW6R StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £58.71
FW6R StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £75.65
FW6R StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop In Stock £7.60
