Add more connectivity to your MacBook or other USB-C laptop, with 4K video, Gigabit Ethernet, two USB 3.0 ports and an SD card reader, plus power and charge as you work. Expand the connectivity of your USB-C enabled laptop. This USB-C multiport adapter lets you turn your laptop into a powerful workstation, virtually anywhere you go, and eliminates the hassle of carrying and connecting many different port adapters. The USB-C adapter lets you add 4K Ultra HD HDMI video output, two USB 3.0 Type-A ports, one Gigabit Ethernet port and one SD card reader slot through your laptop's USB-C port.
You can also use your laptop's USB-C power adapter to power both the multiport adapter and your laptop simultaneously, with support for USB Power Delivery 2.0. It's the ideal accessory for your MacBook Pro or other USB Type-C equipped laptop, and it's also Thunderbolt 3 port compatible.
When coupled with your laptop display, this versatile USB-C multiport adapter makes it easy to create a dual-monitor workstation when you need it. It offers a 4K HDMI port (with audio), so you can easily connect a high-resolution monitor and gain access to more screen space. With higher resolutions, you can view more windows at once and increase your productivity.
The Gigabit Ethernet port ensures reliable wired network access, which is ideal for areas with limited Wi-Fi access. Plus, with two additional USB 3.0 ports (USB Type-A) you can connect your existing peripheral devices, like your mouse or flash drive.
The USB-C adapter also features an SD card reader slot so you can access all of your multimedia content.
This multiport adapter means you don't have to carry multiple power adapters with you. Ideal for mobile use, it features a USB-C port that supports USB Power Delivery 2.0 (USB PD 2.0), so you can use your laptop's USB-C power adapter to power both your laptop and the multiport adapter.
The versatile multiport adapter is compact and lightweight, so it's easy to tuck into your laptop bag. It consolidates multiple ports into a single adapter, which means you don't need to bring along multiple single-function adapters.
To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery and DP Alt Mode.
                Create a powerful workstationWhen coupled with your laptop display, this versatile USB-C multiport adapter makes it easy to create a dual-monitor workstation when you need it. It offers a 4K HDMI port (with audio), so you can easily connect a high-resolution monitor and gain access to more screen space. With higher resolutions, you can view more windows at once and increase your productivity. The Gigabit Ethernet port ensures reliable wired network access, which is ideal for areas with limited Wi-Fi access. Plus, with two additional USB 3.0 ports (USB Type-A) you can connect your existing peripheral devices, like your mouse or flash drive. The USB-C adapter also features an SD card reader slot so you can access all of your multimedia content.
                Designed for easy portabilityThis multiport adapter means you don't have to carry multiple power adapters with you. Ideal for mobile use, it features a USB-C port that supports USB Power Delivery 2.0 (USB PD 2.0), so you can use your laptop's USB-C power adapter to power both your laptop and the multiport adapter. The versatile multiport adapter is compact and lightweight, so it's easy to tuck into your laptop bag. It consolidates multiple ports into a single adapter, which means you don't need to bring along multiple single-function adapters. The DKT30CSDHPD is backed by a StarTech.com 3-year warranty and free lifetime technical support. Note: To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery and DP Alt Mode.
- StarTech.com USB C Multiport Adapter - Portable USB-C Dock to 4K HDMI, 2-pt USB 3.0 Hub, SD/SDHC, GbE, 60W PD Pass-Through - USB Type-C/Thunderbolt 3 - NEW VERSION AVAILABLE DKT30CSDHPD3 (DKT30CSDHPD) - docking station - USB-C / Thunderbolt 3 - 1GbE
- Product Type
- Docking station
- Docking Interface
- 4.6 cm x 11.6 cm x 1.6 cm
- 86 g
- Grey, black
- Networking
- Gigabit Ethernet
- 3-year warranty
- Designed For
- P/N: ARMCBCL, ARMPIVOT, ARMPIVOTB, ARMPIVOTE, ARMPIVOTE2, ARMPIVOTHD, ARMPIVOTV2, ARMPIVSTND, ARMSLIM, ARMUNONB, ARMUNONB1, FPPNEUSTND, LTRISERP, MONSTADJD, MONSTADJDL
- Product Type
- Docking station
- 4.6 cm
- 11.6 cm
- 1.6 cm
- 86 g
- Enclosure Colour
- Grey, black
- Data Link Protocol
- Gigabit Ethernet
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0
- Expansion Slots
- 1 (total) / 1 (free) x SD / MMC Memory Card
- 2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x USB-C - 24 pin USB-C (power only) , Video - HDMI input - 19 pin HDMI Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
- Cables Included
- 1 x USB-C cable - 15.2 cm
- USB powered, full duplex support
- FCC, RoHS, WEEE, RCM, UASP (USB Attached SCSI Protocol)
- OS Required
- Google Chrome OS, Apple MacOS X 10.11 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- Limited warranty - 3 years
- 0 °C
- 55 °C
- Designed For
|  | StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £8.54 |
|  | StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female | In Stock | £9.71 |
|  | StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 | In Stock | £55.27 |
|  | StarTech.com USB-C Multifunction Adapter | In Stock | £45.80 |
|  | StarTech.com USB-C to 4K HDMI Adapter with Power Delivery | In Stock | £44.93 |
|  | StarTech.com USB-C to VGA Adapter with PD | In Stock | £11.93 |
|  | StarTech.com USB-C to 4K HDMI Adapter w/ PD | In Stock | £20.26 |
|  | StarTech.com USB-C Adapter - PD - Silver | In Stock | £26.25 |
|  | StarTech.com USB C Adapter - 4K HDMI, GbE | In Stock | £25.54 |
|  | StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 | In Stock | £68.98 |
|  | StarTech.com USB-C Multiport Adapter Docking Station | In Stock | £118.27 |
|  | StarTech.com USB-C Multiport Adapter HDMI - SD Reader - 2xA 1xC - PD3.0 | In Stock | £59.47 |
|  | StarTech.com USB-C Multiport Adapter with Unfolding Cable - HDMI1.4 - USB | In Stock | £36.73 |
|  | StarTech.com USB C Multiport Adapter - USB-C to 4K HDMI/PD/USB -Mini Dock | In Stock | £22.75 |
|  | StarTech.com USB C Multiport Adapter 4K | In Stock | £30.95 |
|  | StarTech.com USBC Multiport Adapter 4K HDMI | In Stock | £26.15 |
|  | StarTech.com USB C Multiport Adapter PD, 4K | In Stock | £19.96 |
|  | StarTech.com USB-C Multiport Adapter HDMI | In Stock | £50.79 |
|  | StarTech.com USB C Multiport Adapter | In Stock | £20.49 |
|  | StarTech.com Multiport Adapter HDMI/VGA | In Stock | £33.60 |
|  | StarTech.com USB C Multiport Adapter, 4K | In Stock | £31.89 |
|  | StarTech.com USB C Multiport Adapter 4K | In Stock | £31.69 |
|  | StarTech.com USB C Mini Dock 4K HDMI | In Stock | £41.49 |
|  | StarTech.com USBC Multiport Adapter 4K 60Hz | In Stock | £43.64 |
|  | StarTech.com USB C Multiport Adapter 2 HDMI | In Stock | £63.61 |
|  | StarTech.com USBC Multiport Adapter 4K 60Hz | In Stock | £29.52 |
|  | StarTech.com USB-C Multiport Adapter | In Stock | £46.99 |
|  | StarTech.com USB C Multiport Adapter | In Stock | £81.16 |
|  | StarTech.com 4-Port USB-C Hub, 5Gbps, PD | In Stock | £38.84 |
|  | StarTech.com USB-C Multiport Adapter, HDMI | In Stock | £31.51 |
|  | StarTech.com USB-C Multiport Adapter, HDMI | In Stock | £27.89 |
|  | StarTech.com USB-C Triple Monitor Docking Station | In Stock | £142.84 |
|  | StarTech.com USB-C Multiport Adapter - HDMI/DP | In Stock | £42.02 |
|  | StarTech.com USB-C Multiport Adapter - HDMI/VGA | In Stock | £26.89 |
|  | StarTech.com USB-C Speakerphone Dock | In Stock | £77.32 |
|  | StarTech.com USB-C Triple-Monitor Adapter | In Stock | £85.93 |
|  | StarTech.com USB-C/USB-A Multiport Adapter | In Stock | £51.84 |
|  | StarTech.com USB-C Triple-Monitor Adapter | In Stock | £85.35 |
