StarTech.com DC Power Adapter - 5V, 3A
Quicklinx: CWSMWS00 Mfr#: SVA5N3NEUA
Hurry, only 1 left in stock!
£12.31 ex VAT
£14.77 inc VAT
Replace your lost or failed power adapter. This 5V power supply can provide a power source for any electronic device that has an N-type barrel and requires 5volts and up to 3amps of power.
The DC power supply is a perfect replacement for the lost or damaged power adapter you've used to power your existing electronics.
When downtime isn't an option, keeping spare power adapters on hand ensures that you won't be left waiting for a replacement to arrive or have to replace your devices just for the sake of a compatible power source.
  • Replace your failed or lost power adapter
    The adapter is a perfect replacement for the lost or damaged power adapter you've used to power your existing electronics.
  • Keep a spare power adapter on hand
StarTech.com DC Adapter - 3A / 5V Power Adapter - Replacement Power Adapter - DC Power Supply - Universal Power Adapter - AC Adapter (SVA5N3NEUA) - power adapter
Power adapter - external
204 g
Australia, Japan, North America, United Kingdom, Europe
Input Voltage
AC 100-240 V
Output Voltage
DC 5 V
4 power plug adapters
3.2 cm x 7.6 cm x 5.5 cm
P/N: 110VDSLEX2EU, 110VDSLEX2GB, 110VDSLEXT2, DSRXL, MCM1110MMLC, MST14DP123DP, MSTDP123DP, MSTDP123HD, MSTDP124DP, MSTMDP123DP, MSTMDP123HD, MSTMDP124DP, SP123DP, ST122HD4KU, ST122PROEU, ST122VGA, ST124PROEU, sv211kdvieu, SV231USBLC, SVUSBPOWEREU, USB2001EXTV, USB2004EXTV, VS221HD2VGA, VS221VGA2HD
Input Voltage
AC 100-240 V
Output Voltage
DC 5 V
Max Electric Current
3 A
UL, FCC, RoHS
3.2 cm
7.6 cm
5.5 cm
204 g
P/N: 110VDSLEX2EU, 110VDSLEX2GB, 110VDSLEXT2, DSRXL, MCM1110MMLC, MST14DP123DP, MSTDP123DP, MSTDP123HD, MSTDP124DP, MSTMDP123DP, MSTMDP123HD, MSTMDP124DP, SP123DP, ST121UTP232, ST122HD4KU, ST122PRO, ST122PROEU, ST122PROGB, ST122VGA, ST124PRO, ST124PROEU, SV211KDVI, sv211kdvieu, SV211KDVIGB, SV231USB, SV231USBGB, SV231USBLC, SV431DVIUA, SV431DVIUAGB, SV431DVIUAHR, SVUSBPOWER, SVUSBPOWEREU, USB2001EXTV, USB2004EXTV, VS221HD2VGA, VS221VGA2HD
CWSM StarTech.com Multi Stream Transport Hub – DisplayPort 1.2 to Triple Head DisplayPort MST Hub In Stock £37.96
CWSM StarTech.com Multi Stream Transport Hub – Mini DisplayPort 1.2 to Triple Head DisplayPort MST Hub In Stock £34.58
CWSM StarTech.com 4-port USB 2.0 Over Cat5 or Cat6 Extender (50m) In Stock £150.50
CWSM StarTech.com Fiber Media Converter - w/ SFP In Stock £67.70
CWSM StarTech.com 1 Port USB 2.0 Extender Kit In Stock £130.30
CWSM StarTech.com Universal DC Power Adapter for Industrial USB Hubs - 20V In Stock £41.80
