StarTech.com 4 Port DVI USB KVM Switch with Audio & USB Hub
Quicklinx: 5CBPWS00 Mfr#: SV431DVIUAGB
This 4 port DVI USB KVM Switch lets you control four USB enabled, DVI capable computers from a single USB keyboard and mouse peripheral set. Ideal for multimedia applications, the switch supports audio and microphone switching, allowing you to switch between audio/mic channels either independently or simultaneously when switching between computers for KVM control. The DVI USB KVM switch features an integrated USB 2.0 hub which allows you to use shared USB peripherals from the control point as if the devices were connected directly to the slave computers - an economical solution that lets you use USB peripherals between computers (when selected) without the expense of buying individual peripherals for each slave computer.
StarTech.com 4 Port DVI USB KVM Switch with Audio and 2 port USB 2.0 Hub - KVM / audio / USB switch - 4 ports
Subtype
KVM
Ports
4 x KVM / audio / USB
KVM Users Qty
1 local user
25.3 cm x 11.5 cm x 4.5 cm
1.7 kg
United Kingdom
3-year warranty
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1440 @ 70 Hz
Built-in Devices
USB Hub
Status Indicators
Port status
4 x USB 2.0 Type B , Display / video: 4 x DVI-Digital - 18+5 pin combined DVI (Single-Link) , 4 x audio output mini-jack , 4 x microphone input mini-jack , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , Display / video: 1 x DVI-Digital - 18+5 pin combined DVI (Single-Link) , 2 x USB 2.0 Type A , 1 x audio output mini-jack , 1 x microphone input mini-jack
External power adapter
United Kingdom
25.3 cm
11.5 cm
4.5 cm
1.7 kg
Limited warranty - 3 years
5CBP StarTech.com 1U Rackmount Brackets for KVM Switch (SV431 Series) In Stock £22.32
5CBP StarTech.com DC Power Adapter - 5V, 3A In Stock £12.01
5CBP StarTech.com DC Power Adapter - 5V, 3A In Stock £12.31
