StarTech.com DC Power Adapter - 5V, 2A
Quicklinx: CWSNWS00 Mfr#: SVA5H2NEUA
£9.91 ex VAT
£11.89 inc VAT
Replace your lost or failed power adapter. This replacement power adapter can provide a power source for any electronic device that has an H type barrel jack and requires 5 volts and up to 2 amps of power.
The adapter is a perfect replacement for the lost or damaged power adapter you've used to power your existing electronics.
When downtime isn't an option, keeping spare power adapters on hand ensures that you won't be left waiting for a replacement to arrive or have to replace your devices just for the sake of a compatible power source.
This power adapter is a direct replacement for the power adapters included with the following StarTech.com products: Dual-Bay 2.5in Hard Drive Enclosure (S252BU33R); 3-Port Portable USB 3.0 Hub plus Gigabit Ethernet (ST3300GU3B); 4 Port Compact Black USB 2.0 Hub (ST4202USB); 4 Port Black USB 2.0 Hub (ST4202USBGB); 7 Port Compact Black USB 2.0 Hub (ST7202USB); 7 Port Black USB 2.0 Hub (ST7202USBGB); 15m USB 2.0 Active Cable with 4 Port Hub (USB2EXT4P15M); 10m USB 3.0 Active Extension Cable (USB3AAEXT10M); 3m USB 3.0 Active Extension Cable (USB3AAEXT3M); 5m USB 3.0 Active Extension Cable (USB3AAEXT5M); 4K HDMI 4-Port Video Splitter (ST124HD4K); Wireless Display Adapter with HDMI (WIFI2HDMCGE); 4-Port HDMI Automatic Video Switch (VS421HD4K).
  • Reliable power output
    This power adapter provides a stable 5 V output, essential for the optimal functioning of various devices.
  • Wide voltage compatibility
    Operates within a voltage range of AC 110-240 V, suitable for international use.
  • Robust safety standards
    The adapter meets multiple compliance standards including UL and FCC, ensuring safe operation.
  • Convenient external design
    Designed in an external form factor, this adapter is easy to connect and use in diverse settings.
StarTech 5V, 2A DC Adapter - Universal - 10W - DC Adapter - Power Adapter (SVA5H2NEUA) - power adapter
Power adapter - external
400 g
Australia, Japan, North America, United Kingdom, Europe
Input Voltage
AC 110-240 V
Output Voltage
5 V
4 power plug adapters
P/N: DS51002, DS51002EU, DS51072, PM1115P2, PM1115U2, ST121UTPDVGB, ST121WHD2, ST122HD4K, ST124HD4K, ST3300GU3B, ST4202USBGB, ST7202USBGB, USB2AAEXT10M, USB2AAEXT15M, USB2AAEXT20M, USB2AAEXT25M, USB2AAEXT35M, USB2AAEXT5M, USB2EXT4P15M, USB3AAEXT10M, USB3AAEXT3M, USB3AAEXT5M, USBDUP12, VS221HD4K
Input Voltage
AC 110-240 V
Output Voltage
5 V
Max Electric Current
2 A
UL, FCC, RoHS, WEEE, RCM
400 g
P/N: DS51002, DS51002EU, DS51072, PM1115P2, PM1115U2, ST121UTPDVGB, ST121UTPDVI, ST121WHD2, ST122HD4K, ST124HD4K, ST3300GU3B, ST4202USB, ST4202USBGB, ST7202USB, ST7202USBGB, USB2AAEXT10M, USB2AAEXT15M, USB2AAEXT20M, USB2AAEXT25M, USB2AAEXT35M, USB2AAEXT5M, USB2EXT4P15M, USB3AAEXT10M, USB3AAEXT3M, USB3AAEXT5M, USBDUP12, VS221HD4K
CWSN StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £15.73
CWSN StarTech.com 3m USB 3.0 Active Extension Cable - M/F In Stock £69.06
CWSN StarTech.com 5m USB 3.0 Active Extension Cable - M/F In Stock £84.93
CWSN StarTech.com 10m USB 3.0 Active Extension Cable - M/F In Stock £112.84
CWSN StarTech.com 20m USB 2.0 Active Extension Cable - M/F In Stock £76.40
CWSN StarTech.com 15m USB 2.0 Active Extension Cable - M/F In Stock £61.53
CWSN StarTech.com 1:2 Standalone USB 2.0 Flash Drive Duplicator and Eraser In Stock £114.42
CWSN StarTech.com 10m USB 2.0 Active Extension Cable - M/F In Stock £53.10
CWSN StarTech.com 25m USB 2.0 Active Extension Cable - M/F In Stock £95.29
CWSN StarTech.com 5m USB 2.0 Active Extension Cable - M/F In Stock £37.96
CWSN StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable In Stock £39.78
CWSN StarTech.com DC Power Adapter - 9V, 2A In Stock £12.21
CWSN StarTech.com DC Power Adapter - 5V, 3A In Stock £12.01
CWSN StarTech.com USB Network LPR Print Server In Stock £38.90
CWSN StarTech.com 4-Port HDMI Switch - 4K In Stock £37.23
CWSN StarTech.com 2-Port HDMI Switch - 4K In Stock £31.28
CWSN StarTech.com DC Power Adapter - 5V, 2A In Stock £9.91
CWSN StarTech.com Universal DC Power Adapter for Industrial USB Hubs - 20V In Stock £41.80
