StarTech.com USB Network LPR Print Server
Quicklinx: BT5XWS00 Mfr#: PM1115U2
Wired / Wireless: Wired
Speed: 100Mbps
Protocol: Fast Ethernet, Ethernet
Interface: USB 2.0
Compatibility: Mac, PC
26 In Stock
£37.19 ex VAT
£44.62 inc VAT
Share a standard USB printer with multiple users over an Ethernet network. This palm-sized print server makes it easy to share a USB printer with users on your network. It's the ideal solution for home or small office networks.
Enjoy cost-efficient network printing for multiple users. The USB 10/100 Mbps print server lets you share one USB printer with multiple users on your network, instead of having to buy separate printers for each individual workstation.
With web-based management, you can set up and monitor the printer server through a web browser, so you can place your printer at any convenient shared location - there's no need to put your printer next to your computer. You can send print jobs to another user in your home or office, or even to a printer in another country.
Compact and lightweight, the print server is easy to install with its straightforward installation wizards and remote web-based management. You simply use a USB cable to connect the print server to your printer's USB port, then use an RJ45 networking cable to connect it to the rest of your network.
The printer server supports the Line Printer Remote (LPR) protocol which enables Internet printing. It also supports Bonjour Print Services, making it easier to find and configure printers on your network.
  • Reliable, cost-efficient network printing
  • Place your shared printer in a convenient location
  • Easy to use and install
  • Supports LPR network printing and Bonjour Print Services
    The printer server supports the Line Printer Remote (LPR) protocol which enables Internet printing. It also supports Bonjour Print Services, making it easier to find and configure printers on your network. The PM1115U2 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com 10/100Mbps Ethernet to USB 2.0 Network Print Server - Windows 10 - LPR - LAN USB Print Server Adapter (PM1115U2) - print server - USB 2.0 - 10/100 Ethernet
Print server
External
Interface (Bus) Type
USB 2.0
Ports
10/100 Ethernet
5.2 cm x 5.2 cm x 2.5 cm
60 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
Jumbo frame size: 9000
Network / Transport Protocol
LPR/LPD, Bonjour
IEEE 802.3, IEEE 802.3u
Microsoft Windows XP, Microsoft Windows Server 2003, Apple MacOS X 10.x or later, Microsoft Windows Server 2008 R2, Microsoft Windows 7 / Windows 8 (32 bits), Microsoft Windows 7 / Windows 8 (64 bits), Microsoft Windows Server 2012 (32/64-bits), Windows RT
P/N: SVA5H2NEUA
Print server
External
USB 2.0
Ports
10/100 Ethernet
Wired
Cabling Type
Ethernet, Fast Ethernet
Data Transfer Rate
100 Mbps
LPR/LPD, Bonjour
Status Indicators
Power, link/activity
Full duplex capability, auto-uplink (auto MDI/MDI-X), Jumbo Frames support
1 x 100Base-TX - RJ-45
1 x network cable (external)
FCC, RoHS
Software Included
Drivers & Utilities
5.2 cm
5.2 cm
2.5 cm
60 g
10 - 90%
P/N: SVA5H2NEUA
BT5X StarTech.com DC Power Adapter - 5V, 2A In Stock £9.91
Speed: 100Mbps
Protocol: Ethernet
Interface: USB 2.0
Compatibility: Mac
Compatibility: PC
