Replace your lost or failed power adapter. This replacement power adapter can provide a power source for any electronic device that has an H type barrel jack and requires 5 volts and up to 2 amps of power.
The adapter is a perfect replacement for the lost or damaged power adapter you've used to power your existing electronics.
When downtime isn't an option, keeping spare power adapters on hand ensures that you won't be left waiting for a replacement to arrive or have to replace your devices just for the sake of a compatible power source.
This power adapter is a direct replacement for the power adapters included with the following StarTech.com products: Dual-Bay 2.5in Hard Drive Enclosure (S252BU33R); 3-Port Portable USB 3.0 Hub plus Gigabit Ethernet (ST3300GU3B); 4 Port Compact Black USB 2.0 Hub (ST4202USB); 4 Port Black USB 2.0 Hub (ST4202USBGB); 7 Port Compact Black USB 2.0 Hub (ST7202USB); 7 Port Black USB 2.0 Hub (ST7202USBGB); 15m USB 2.0 Active Cable with 4 Port Hub (USB2EXT4P15M); 10m USB 3.0 Active Extension Cable (USB3AAEXT10M); 3m USB 3.0 Active Extension Cable (USB3AAEXT3M); 5m USB 3.0 Active Extension Cable (USB3AAEXT5M); 4K HDMI 4-Port Video Splitter (ST124HD4K); Wireless Display Adapter with HDMI (WIFI2HDMCGE); 4-Port HDMI Automatic Video Switch (VS421HD4K).
Reliable power output
This power adapter provides a stable 5 V output, essential for the optimal functioning of various devices. -
Wide voltage compatibility
Operates within a voltage range of AC 110-240 V, suitable for international use. -
Robust safety standards
The adapter meets multiple compliance standards including UL and FCC, ensuring safe operation. -
Convenient external design
Designed in an external form factor, this adapter is easy to connect and use in diverse settings.
- StarTech.com 5V, 2A DC Adapter - Universal - 10W - DC Adapter - Power Adapter (SVA5H2NEUA) - power adapter
- Power adapter - external
- 400 g
- Localisation
- Australia, Japan, North America, United Kingdom, Europe
- Input Voltage
- AC 110-240 V
- Output Voltage
- 5 V
- Included Accessories
- 4 power plug adapters
- 2-year warranty
- Designed For
- P/N: DS51002, DS51002EU, DS51072, PM1115P2, PM1115U2, ST121UTPDVGB, ST121WHD2, ST122HD4K, ST124HD4K, ST3300GU3B, ST4202USBGB, ST7202USBGB, USB2AAEXT10M, USB2AAEXT15M, USB2AAEXT20M, USB2AAEXT25M, USB2AAEXT35M, USB2AAEXT5M, USB2EXT4P15M, USB3AAEXT10M, USB3AAEXT3M, USB3AAEXT5M, USBDUP12, VS221HD4K
- Localisation
- Input Voltage
- AC 110-240 V
- Output Voltage
- 5 V
- Max Electric Current
- 2 A
- UL, FCC, RoHS, WEEE, RCM
- Limited warranty - 2 years
- 400 g
- Designed For
- P/N: DS51002, DS51002EU, DS51072, PM1115P2, PM1115U2, ST121UTPDVGB, ST121UTPDVI, ST121WHD2, ST122HD4K, ST124HD4K, ST3300GU3B, ST4202USB, ST4202USBGB, ST7202USB, ST7202USBGB, USB2AAEXT10M, USB2AAEXT15M, USB2AAEXT20M, USB2AAEXT25M, USB2AAEXT35M, USB2AAEXT5M, USB2EXT4P15M, USB3AAEXT10M, USB3AAEXT3M, USB3AAEXT5M, USBDUP12, VS221HD4K
StarTech.com 12V DC 1.5A Universal Power Adapter | In Stock | £15.63 |
StarTech.com 3m USB 3.0 Active Extension Cable - M/F | In Stock | £71.01 |
StarTech.com 5m USB 3.0 Active Extension Cable - M/F | In Stock | £82.51 |
StarTech.com 10m USB 3.0 Active Extension Cable - M/F | In Stock | £116.91 |
StarTech.com 20m USB 2.0 Active Extension Cable - M/F | In Stock | £82.04 |
StarTech.com 15m USB 2.0 Active Extension Cable - M/F | In Stock | £64.17 |
StarTech.com 1:2 Standalone USB 2.0 Flash Drive Duplicator and Eraser | In Stock | £118.08 |
StarTech.com 10m USB 2.0 Active Extension Cable - M/F | In Stock | £53.76 |
StarTech.com 25m USB 2.0 Active Extension Cable - M/F | In Stock | £93.69 |
StarTech.com 5m USB 2.0 Active Extension Cable - M/F | In Stock | £38.41 |
StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable | In Stock | £40.26 |
StarTech.com 15m USB 2.0 Active Cable with 4 Port Hub | In Stock | £77.21 |
StarTech.com 4K HDMI 4-Port Video Splitter | In Stock | £62.00 |
StarTech.com DC Power Adapter - 9V, 2A | In Stock | £12.30 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £11.71 |
StarTech.com USB Network LPR Print Server | In Stock | £39.72 |
StarTech.com 4-Port HDMI Switch - 4K | In Stock | £39.58 |
StarTech.com 2-Port HDMI Switch - 4K | In Stock | £32.74 |
StarTech.com Universal DC Power Adapter for Industrial USB Hubs - 20V | In Stock | £40.15 |
