Replace your lost or failed power adapter. This replacement power adapter can provide a power source for any electronic device that has an M type barrel jack and requires 12volts and up to 5amps of power. The adapter is a perfect replacement for the lost or damaged power adapter you've used to power your existing electronics. When downtime isn't an option, keeping spare power adapters on hand ensures that you won't be left waiting for a replacement to arrive or have to replace your devices just for the sake of a compatible power source.
                Replace your failed or lost power adapterThe adapter is a perfect replacement for the lost or damaged power adapter you've used to power your existing electronics.
                Keep a spare power adapter on handWhen downtime isn't an option, keeping spare power adapters on hand ensures that you won't be left waiting for a replacement to arrive or have to replace your devices just for the sake of a compatible power source.
- StarTech.com Replacement 12V DC Power Adapter - 12 Volts 5 Amps - Power adapter - AC 100-240 V - SVA12M5NA - power adapter
- Power adapter - external
- Localisation
- Australia, Japan, North America, United Kingdom, Europe
- Input Voltage
- AC 100-240 V
- Output Voltage
- 12 V
- Included Accessories
- Power plug adapter (EU), power plug adapter (UK), power plug adapter (AU), power plug adapter (NA)
- 2-year warranty
- Designed For
- StarTech.com 4-Port Industrial USB 3.0 5Gbps Hub, Rugged USB Hub w/15kV Air/8kV Contact ESD and Surge Protection, DIN/Wall/Desk Mountable USB-A Hub, USB Expansion Hub with Locking Ports - Metal Construction (5G4AINDNP-USB-A-HUB)
- Localisation
- Input Voltage
- AC 100-240 V
- Output Voltage
- 12 V
- Max Electric Current
- 5 A
- Cables Included
- Power cable
- UL, FCC, RoHS, WEEE, RCM
- Limited warranty - 2 years
- Designed For
|  | StarTech.com VGA to Cat 5 Monitor Extender Kit (250ft/80m) - VGA Cat5 Extender | In Stock | £119.00 |
|  | StarTech.com PCI Express to 2 PCI & 2 PCIe Expansion Enclosure System - Full Length | In Stock | £319.14 |
|  | StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub | In Stock | £233.24 |
|  | StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub | In Stock | £243.20 |
|  | StarTech.com 2 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub | In Stock | £114.49 |
|  | StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD | In Stock | £40.39 |
|  | StarTech.com 2 Port USB HDMI KVM Switch with Audio and USB 2.0 Hub | In Stock | £153.35 |
|  | StarTech.com 4 Port USB DisplayPort KVM Switch with Audio | In Stock | £240.14 |
|  | StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub | In Stock | £128.11 |
|  | StarTech.com 2 Port Professional USB DisplayPort KVM Switch with Audio | In Stock | £189.49 |
|  | StarTech.com Long Range USB VGA KVM Console Extender over Cat5 UTP - 1000 ft | In Stock | £288.51 |
|  | StarTech.com DisplayPort USB KVM Switch | In Stock | £287.60 |
|  | StarTech.com PCI Express to 4 Slot PCI Expansion System | In Stock | £365.65 |
|  | StarTech.com 4 Port High Speed HDMI Video Splitter w/ Audio | In Stock | £89.31 |
|  | StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub | In Stock | £98.93 |
|  | StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £452.75 |
|  | StarTech.com 12V DC 1.5A Universal Power Adapter | In Stock | £15.65 |
|  | StarTech.com 2 Port High Speed HDMI Video Splitter and Signal Amplifier | In Stock | £68.05 |
|  | StarTech.com 2 Port DVI USB KVM Switch with Audio and USB 2.0 Hub | In Stock | £124.31 |
|  | StarTech.com 4 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £142.79 |
|  | StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £273.74 |
|  | StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £309.46 |
|  | StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch | In Stock | £600.89 |
|  | StarTech.com Fiber Media Converter Gigabit 1000Mbps MM Fibre LC 550m | In Stock | £149.37 |
|  | StarTech.com Gigabit Ethernet Multi Mode Fiber Media Converter SC 550m - 1000 Mbps | In Stock | £145.25 |
|  | StarTech.com Gigabit Ethernet Single Mode Fiber Media Converter SC 40 km - 1000 Mbps | In Stock | £308.76 |
|  | StarTech.com 10/100 Mbps Multi Mode Fiber Media Converter SC 2 km | In Stock | £69.74 |
|  | StarTech.com USB Dual VGA over Cat5 KVM Console Extender - 650 ft / 200m | In Stock | £336.25 |
|  | StarTech.com HDMI Over Single Cat 5e / 6 Extender with Power Over Cable - 230 ft (70m) | In Stock | £186.15 |
|  | StarTech.com HDMI Over CAT5/CAT6 Extender with Power Over Cable - 165 ft (50m) | In Stock | £90.68 |
|  | StarTech.com Standalone 2.5 / 3.5" SATA Hard Drive Duplicator and Eraser w/ High Duplication Speed | In Stock | £297.61 |
|  | StarTech.com USB 3.0 SATA III Hard Drive Docking Station SSD / HDD with UASP | In Stock | £37.71 |
|  | StarTech.com HDMI Over CAT5e / CAT6 Extender with Power Over Cable - 330 ft (100m) | In Stock | £310.26 |
|  | StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A) | In Stock | £25.34 |
|  | StarTech.com 2 Port HDMI Switch w/ Automatic and Priority Switching - 1080p | In Stock | £55.88 |
|  | StarTech.com 2X2 HDMI Matrix Switch w/ Automatic and Priority Switching 1080p | In Stock | £81.48 |
|  | StarTech.com USB 3.0 / eSATA Dual Hard Drive Docking Station with UASP for 2.5/3.5in SATA SSD / HDD | In Stock | £62.23 |
|  | StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black | In Stock | £46.54 |
|  | StarTech.com USB 3.0 Dual Hard Drive Docking Station with UASP for 2.5/3.5in SSD / HDD – SATA 6Gbps | In Stock | £57.36 |
|  | StarTech.com USB 3.0 / eSATA to 2.5 / 3.5" SATA HDD / SSD Duplicator Dock – Hard Drive Cloner 6Gbps | In Stock | £68.59 |
|  | StarTech.com Standalone 2.5 / 3.5" SATA Hard Drive Duplicator w/ Multi HDD SSD Image Backup Library | In Stock | £262.35 |
|  | StarTech.com 4x4 HDMI Matrix Switch with Picture-and-Picture Multiviewer or Video Wall | In Stock | £624.24 |
|  | StarTech.com 7 Port USB 3.0 Hub Desktop | In Stock | £61.74 |
|  | StarTech.com USB HDD dock for SATA & IDE | In Stock | £61.23 |
|  | StarTech.com 2-port Dual VGA KVM Switch | In Stock | £67.05 |
|  | StarTech.com USB 3.0 Standalone Eraser Dock | In Stock | £205.80 |
|  | StarTech.com GbE Fiber Media Converter 10km | In Stock | £179.13 |
|  | StarTech.com GbE Fiber Media Converter 20km | In Stock | £162.84 |
|  | StarTech.com 2 Port Dual DP KVM Switch - 4K | In Stock | £245.82 |
|  | StarTech.com USB and SATA Cloner / Eraser | In Stock | £460.70 |
|  | StarTech.com SATA SSD/HDD Eraser/Dock - 4Kn | In Stock | £232.95 |
|  | StarTech.com USB C to SATA Adapter Cable | In Stock | £34.51 |
|  | StarTech.com ST12MHDLAN4K Receiver | In Stock | £253.06 |
|  | StarTech.com Dual-Bay SATA HDD/SSD Dock | In Stock | £51.20 |
|  | StarTech.com 4 Port USB 3.0 Hub A to C & A | In Stock | £41.13 |
|  | StarTech.com 7 Port USB C Hub - C to C & A | In Stock | £65.16 |
|  | StarTech.com Universal DC Power Adapter for Industrial USB Hubs - 20V | In Stock | £40.15 |
