Replace your lost or failed power adapter. This replacement power adapter can provide a power source for any electronic device that has an M type barrel jack and requires 12volts and up to 5amps of power. The adapter is a perfect replacement for the lost or damaged power adapter you've used to power your existing electronics. When downtime isn't an option, keeping spare power adapters on hand ensures that you won't be left waiting for a replacement to arrive or have to replace your devices just for the sake of a compatible power source.
Replace your failed or lost power adapter
The adapter is a perfect replacement for the lost or damaged power adapter you've used to power your existing electronics. -
Keep a spare power adapter on hand
- StarTech.com Replacement 12V DC Power Adapter - 12 Volts 5 Amps - Power adapter - AC 100-240 V - SVA12M5NA - power adapter
- Power adapter - external
- Localisation
- Australia, Japan, North America, United Kingdom, Europe
- Input Voltage
- AC 100-240 V
- Output Voltage
- 12 V
- Included Accessories
- Power plug adapter (EU), power plug adapter (UK), power plug adapter (AU), power plug adapter (NA)
- 2-year warranty
- Designed For
- P/N: ET10GSFP, HB30A3A1CST, HB30C3A1CST, HB30C5A2CSC, HB30C5A2CST, IES101G2SFPW, IES81GW, RKPNLLT, S351BMU33ET, S351BMU33ETG, SDOCK1EU3P2, SDOCK2U33V, ST121HDBTDK, ST121HDBTL, ST12MHDLAN4R, ST7C51224, ST7C51224EU, SU2DUPERA11, SV231DPDDUA2, SV431DL2DU3A, SV431DPDDUA2, SV431DPUA2, USB31C2SAT3
- Localisation
- Input Voltage
- AC 100-240 V
- Output Voltage
- 12 V
- Max Electric Current
- 5 A
- Cables Included
- Power cable
- UL, FCC, RoHS, WEEE, RCM
- Limited warranty - 2 years
- Designed For
- P/N: 110VDSLEXT, 110VDSLEXTEU, 110VDSLEXTGB, AP150WN1X1OD, AP150WN1X1OE, CABCONS1716I, EOC1110K, EOC1110R, ET1000S40LC2, ET10GSFP, ET90110SC2, ET90110SM302, ET90110ST2, ET90110WDM2, ET91000LC2, ET91000LCOAM, ET91000SC2, ET91000SFP2, ET91000SM10, ET91000SM20, ET91000SM402, HB30A3A1CST, HB30C3A1CST, HB30C5A2CSC, HB30C5A2CST, IES101G2SFPW, IES81GW, IM12D1500P, IREXT2, MCM110SC2, MCM110SC2EU, MCM110SC2GB, MCM110SC2P, MCM110ST2, MCM110ST2EU, MCM110ST2GB, NETRS2321P, NETRS2321POE, PEX2PCI4, PEX2PCIE4L, R300WN22GA, R300WN22GAEU, RACKCOND1701, RACKCOND17HD, RACKCONS1908, RACKCONS1916, RKPNLLT, S3510BMU33, S3510SMU33, S351BMU33ET, S351BMU33ETG, S3520BU33ER, S352BU33HR, S352BU33RER, SATDOCK2REU3, SATDOCKU3S, SATDUP11, SATDUP11IMG, SDOCK1EU3P, SDOCK1EU3P2, SDOCK2U33, SDOCK2U33EB, SDOCK2U33RE, SDOCK2U33V, SDOCKU33BV, SDOCKU33EBV, SDOCKU33EF, SDOCKU33HW, ST1212T, ST1214T, ST1216PRO, ST1218T, ST121EXT, ST121HDBT5, ST121HDBTDK, ST121HDBTE, ST121HDBTL, ST121HDBTPW, ST121HDWP, ST121R, ST121SHD50, ST121UTP, ST121UTPEP, ST121UTPHD2, ST122DVIA, ST122HDMI2, ST122PROA, ST122UTPA, ST122UTPAL, ST122VGAU, ST124DVIA, ST124HDMI2, ST124UTPEA, ST128HDMI2, ST12MHDLAN, ST12MHDLAN4R, ST12MHDLANRX, ST222MXA, ST224MX, ST424HDBT, ST424MX, ST4300U3C3, ST4300USBM, ST4CU424, ST7300U3M, ST7300USB3B, ST7C51224, ST7C51224EU, STUTPEALR, STUTPWALLA, SU2DUPERA11, SV1631DUSB, SV1631DUSBU, SV231DD2DUA, SV231DDVDUA, SV231DPDDUA, SV231DPDDUA2, SV231DPUA, SV231DVGAU2A, SV231DVIUA, SV231DVIUAHR, SV231HDMIUA, SV231QDVIUA, SV231TDVIUA, SV431DD2DUA, SV431DDVDUA, SV431DL2DU3A, SV431DPDDUA2, SV431DPUA, SV431DPUA2, SV431DUSBU, SV431DVGAU2A, SV431DVIUAQV, SV431TDVIUA, SV441DUSBI, SV565DUTPU, SV565FXDUSA, SV565UTPUL, SV831DUSB, SV831DUSBAU, SV831DUSBU, SV831DUSBUK, SV841HDIE, SV841HDIEGB, UNIDOCKU33, USB31C2SAT3, VS221HDQ, VS222HDQ, VS420RDVIA, VS421HDPIP, VS424HDPIP, VS440HDMI, VS721MULTI
StarTech.com 4x4 VGA Matrix Video Switch Splitter with Audio | In Stock | £213.47 |
StarTech.com VGA to Cat 5 Monitor Extender Kit (250ft/80m) - VGA Cat5 Extender | In Stock | £114.16 |
StarTech.com PCI Express to 2 PCI & 2 PCIe Expansion Enclosure System - Full Length | In Stock | £284.04 |
StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub | In Stock | £259.75 |
StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub | In Stock | £246.22 |
StarTech.com 2 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub | In Stock | £188.21 |
StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD | In Stock | £38.35 |
StarTech.com 4 Port USB DisplayPort KVM Switch with Audio | In Stock | £257.56 |
StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub | In Stock | £161.20 |
StarTech.com 4 Port DVI Video Splitter with Audio | In Stock | £184.02 |
StarTech.com 2 Port Professional USB DisplayPort KVM Switch with Audio | In Stock | £185.52 |
StarTech.com 2 Port DVI Video Splitter with Audio | In Stock | £98.27 |
StarTech.com DisplayPort USB KVM Switch | In Stock | £265.04 |
StarTech.com PCI Express to 4 Slot PCI Expansion System | In Stock | £287.01 |
StarTech.com 4 Port High Speed HDMI Video Splitter w/ Audio | In Stock | £96.26 |
StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub | In Stock | £91.01 |
StarTech.com 2 Port Quad Monitor Dual-Link DVI USB KVM Switch with Audio & Hub | In Stock | £385.79 |
StarTech.com 12V DC 1.5A Universal Power Adapter | In Stock | £16.93 |
StarTech.com 2 Port High Speed HDMI Video Splitter and Signal Amplifier | In Stock | £78.25 |
StarTech.com 2 Port DVI USB KVM Switch with Audio and USB 2.0 Hub | In Stock | £136.29 |
StarTech.com 2 Port High Resolution USB DVI Dual Link KVM Switch with Audio | In Stock | £218.44 |
StarTech.com 10/100 Mbps Multi Mode Fiber Media Converter ST 2 km | In Stock | £79.16 |
StarTech.com Fiber Media Converter Gigabit 1000Mbps MM Fibre LC 550m | In Stock | £160.44 |
StarTech.com Gigabit Ethernet Multi Mode Fiber Media Converter SC 550m - 1000 Mbps | In Stock | £129.22 |
StarTech.com 10/100 Mbps Multi Mode Fiber Media Converter SC 2 km | In Stock | £78.13 |
StarTech.com USB Dual VGA over Cat5 KVM Console Extender - 650 ft / 200m | In Stock | £364.62 |
StarTech.com 2 Port Triple Monitor DVI USB KVM Switch with Audio & USB 2.0 Hub | In Stock | £334.42 |
StarTech.com HDMI Over Single Cat 5e / 6 Extender with Power Over Cable - 230 ft (70m) | In Stock | £210.13 |
StarTech.com HDMI Video Over IP Gigabit LAN Ethernet Extender Kit - 1080p | In Stock | £348.49 |
StarTech.com HDMI Video Over IP Gigabit LAN Ethernet Receiver for ST12MHDLAN - 1080p | In Stock | £185.25 |
StarTech.com 3.5in Black USB 3.0 External SATA III Hard Drive Enclosure with UASP for SATA 6 Gbps | In Stock | £41.76 |
StarTech.com HDMI Over CAT5/CAT6 Extender with Power Over Cable - 165 ft (50m) | In Stock | £101.44 |
StarTech.com 1 Port RS232 Serial to IP Ethernet Converter / Device Server - Aluminum | In Stock | £112.93 |
StarTech.com Standalone 2.5 / 3.5" SATA Hard Drive Duplicator and Eraser w/ High Duplication Speed | In Stock | £294.98 |
StarTech.com USB 3.0 SATA Hard Drive Docking Station SSD / HDD with integrated Fast Charge USB Hub | In Stock | £38.50 |
StarTech.com USB 3.0 to 2.5/3.5" SATA HDD / SSD Duplicator Dock - Standalone Hard Drive / HDD Clone | In Stock | £64.70 |
StarTech.com USB 3.0 SATA III Hard Drive Docking Station SSD / HDD with UASP | In Stock | £38.91 |
StarTech.com HDMI Over CAT5e / CAT6 Extender with Power Over Cable - 330 ft (100m) | In Stock | £348.25 |
StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A) | In Stock | £60.86 |
StarTech.com 1 Port RS232 Serial Ethernet Device Server - PoE Power Over Ethernet | In Stock | £115.24 |
StarTech.com OAM Managed Gigabit Ethernet Fiber Media Converter - MM LC 550m - 802.3ah Compliant | In Stock | £145.83 |
StarTech.com 2 Port HDMI Switch w/ Automatic and Priority Switching - 1080p | In Stock | £57.56 |
StarTech.com USB 3.0 / eSATA Dual Hard Drive Docking Station with UASP for 2.5/3.5in SATA SSD / HDD | In Stock | £58.48 |
StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black | In Stock | £55.29 |
StarTech.com USB 3.0 Dual Hard Drive Docking Station with UASP for 2.5/3.5in SSD / HDD – SATA 6Gbps | In Stock | £61.59 |
StarTech.com USB 3.0 / eSATA to 2.5 / 3.5" SATA HDD / SSD Duplicator Dock – Hard Drive Cloner 6Gbps | In Stock | £98.69 |
StarTech.com USB 3.0 / eSATA Dual-Bay Trayless 3.5" SATA III Hard Drive Enclosure with UASP | In Stock | £108.49 |
StarTech.com eSATA / USB 3.0 SATA III Hard Drive Docking Station SSD / HDD with UASP | In Stock | £45.51 |
StarTech.com 7 Port USB 3.0 Hub Desktop | In Stock | £68.04 |
StarTech.com USB HDD dock for SATA & IDE | In Stock | £64.73 |
StarTech.com USB 3.0 & eSATA HDD Dock | In Stock | £52.31 |
StarTech.com 2-port Dual VGA KVM Switch | In Stock | £156.84 |
StarTech.com 4-port Dual VGA KVM Switch | In Stock | £170.80 |
StarTech.com USB 3.0 Standalone Eraser Dock | In Stock | £203.19 |
StarTech.com GbE Fiber Media Converter 10km | In Stock | £196.70 |
StarTech.com GbE Fiber Media Converter 20km | In Stock | £183.49 |
StarTech.com HDBaseT Extender Kit - 4K | In Stock | £310.16 |
StarTech.com 2 Port Dual DP KVM Switch - 4K | In Stock | £252.48 |
StarTech.com USB and SATA Cloner / Eraser | In Stock | £530.36 |
StarTech.com SATA SSD/HDD Eraser/Dock - 4Kn | In Stock | £227.59 |
StarTech.com Dual-Bay SATA HDD/SSD Dock | In Stock | £50.18 |
StarTech.com 4 Port USB 3.0 Hub A to C & A | In Stock | £50.82 |
StarTech.com 4 Port USB-C Hub - C to C & A | In Stock | £39.33 |
StarTech.com 7 Port USB C Hub - C to C & A | In Stock | £79.59 |
