Brand
StarTech.com DC Power Adapter - 12V, 2A
Quicklinx: CWSBWS00 Mfr#: SVA12M2NEUA
£13.92 ex VAT
£16.70 inc VAT
Replace your lost or failed power adapter. This 12V DC power supply can provide a power source for any electronic device that has an M-type barrel and requires 12volts and up to 2amps of power. The power supply is a perfect replacement for the lost or damaged 12-volt 2-amp power adapter you've used to power your existing electronics. When downtime isn't an option, keeping spare power adapters on hand ensures that you won't be left waiting for a replacement to arrive or have to replace your devices just for the sake of a compatible power source.
StarTech.com DC Power Adapter - 12V, 2A - Universal Replacement Power Adapter (NA, EU, UK, AU) (SVA12M2NEUA) - power adapter
Power adapter - external
Australia, North America, United Kingdom, Europe
Input Voltage
AC 100-240 V
Output Voltage
12 V
Power plug adapter (EU), power plug adapter (UK), power plug adapter (AU), power plug adapter (NA)
P/N: ET10GSFP, ET91000SM10, ET91000SM20, HB30A3A1CST, HB30C3A1CST, IES101G2SFPW, IES81GW, RKPNLLT, S351BMU33ET, S351BMU33ETG, SDOCKU33EF, ST121HDBTDK, ST121HDBTL, ST121HDWP, ST12MHDLAN4R, SV231DPDDUA2, SV231DVGAU2A, SV431DL2DU3A, SV431DPDDUA2, SV431DPUA2, SV431DVGAU2A, USB312SAT3, USB31C2SAT3
Input Voltage
AC 100-240 V
Output Voltage
12 V
Max Electric Current
2 A
UL, FCC, RoHS, WEEE, RCM
P/N: 110VDSLEXT, 110VDSLEXTEU, 110VDSLEXTGB, AP150WN1X1OD, AP150WN1X1OE, EOC1110K, EOC1110R, ET1000S40LC2, ET10GSFP, ET90110SC2, ET90110SM302, ET90110ST2, ET90110WDM2, ET91000LC2, ET91000LCOAM, ET91000SC2, ET91000SFP2, ET91000SM10, ET91000SM20, ET91000SM402, HB30A3A1CST, HB30C3A1CST, IES101G2SFPW, IES81GW, IM12D1500P, IREXT2, MCM110SC2, MCM110SC2EU, MCM110SC2GB, MCM110SC2P, MCM110ST2, MCM110ST2EU, MCM110ST2GB, NETRS2321P, R300WN22GA, R300WN22GAEU, RKPNLLT, S3510BMU33, S3510SMU33, S351BMU33ET, S351BMU33ETG, SATDOCKU3S, SDOCKU33BV, SDOCKU33EBV, SDOCKU33EF, ST1212T, ST1214T, ST1216PRO, ST1218T, ST121EXT, ST121HDBT5, ST121HDBTDK, ST121HDBTE, ST121HDBTL, ST121HDBTPW, ST121HDFXA, ST121HDWP, ST121R, ST121SHD50, ST121UTP, ST121UTPEP, ST121UTPHD2, ST122DVIA, ST122HDMI2, ST122PROA, ST122UTPA, ST122UTPAL, ST122VGAU, ST124DVIA, ST124HDMI2, ST124UTPEA, ST128HDMI2, ST12MHDLAN, ST12MHDLAN4R, ST12MHDLANRX, ST222MXA, ST224MX, ST424MX, STUTPEALR, STUTPWALLA, SV1631DUSB, SV1631DUSBU, SV231DD2DUA, SV231DDVDUA, SV231DPDDUA, SV231DPDDUA2, SV231DPUA, SV231DVGAU2A, SV231DVIUA, SV231DVIUAHR, SV231HDMIUA, SV231QDVIUA, SV231TDVIUA, SV431DD2DUA, SV431DDVDUA, SV431DL2DU3A, SV431DPDDUA2, SV431DPUA, SV431DPUA2, SV431DUSBU, SV431DVGAU2A, SV431TDVIUA, SV441DUSBI, SV565DUTPU, SV565FXDUSA, SV565UTPUL, SV831DUSB, SV831DUSBU, SV831DUSBUK, SV841HDIE, SV841HDIEGB, USB312SAT3, USB31C2SAT3, VS221HDQ, VS222HDQ, VS420RDVIA, VS440HDMI, VS721MULTI
CWSB StarTech.com VGA to Cat 5 Monitor Extender Kit (250ft/80m) - VGA Cat5 Extender In Stock £111.81
CWSB StarTech.com 4 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £298.59
CWSB StarTech.com 4 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £232.61
CWSB StarTech.com 2 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £230.12
CWSB StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD In Stock £37.13
CWSB StarTech.com 4 Port USB DisplayPort KVM Switch with Audio In Stock £264.39
CWSB StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub In Stock £160.20
CWSB StarTech.com 4 Port DVI Video Splitter with Audio In Stock £176.74
CWSB StarTech.com 2 Port Professional USB DisplayPort KVM Switch with Audio In Stock £185.52
CWSB StarTech.com 2 Port DVI Video Splitter with Audio In Stock £98.74
CWSB StarTech.com Long Range USB VGA KVM Console Extender over Cat5 UTP - 1000 ft In Stock £332.53
CWSB StarTech.com DisplayPort USB KVM Switch In Stock £265.59
CWSB StarTech.com USB DVI KVM Console Extender w/ Serial & Audio Over MM Fiber - 2km In Stock £1,696.91
CWSB StarTech.com 4 Port High Speed HDMI Video Splitter w/ Audio In Stock £101.00
CWSB StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £532.60
CWSB StarTech.com 12V DC 1.5A Universal Power Adapter In Stock £15.78
CWSB StarTech.com 2 Port DVI USB KVM Switch with Audio and USB 2.0 Hub In Stock £131.94
CWSB StarTech.com 2 Port High Resolution USB DVI Dual Link KVM Switch with Audio In Stock £218.44
CWSB StarTech.com 4 Port 1U Rackmount USB KVM Switch with OSD In Stock £159.01
CWSB StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £298.08
CWSB StarTech.com 4x4 HDMI Matrix Video Switch Splitter with Audio and RS232 In Stock £472.74
CWSB StarTech.com 10/100 Mbps Multi Mode Fiber Media Converter ST 2 km In Stock £79.16
CWSB StarTech.com Gigabit Ethernet Multi Mode Fiber Media Converter SC 550m - 1000 Mbps In Stock £113.10
CWSB StarTech.com Gigabit Ethernet Single Mode Fiber Media Converter SC 40 km - 1000 Mbps In Stock £339.30
CWSB StarTech.com 10/100 Mbps Multi Mode Fiber Media Converter SC 2 km In Stock £78.13
CWSB StarTech.com 10/100 Mbps Single Mode Fiber Media Converter SC 30 km In Stock £122.52
CWSB StarTech.com USB Dual VGA over Cat5 KVM Console Extender - 650 ft / 200m In Stock £364.62
CWSB StarTech.com 4 Port Triple Monitor DVI USB KVM Switch with Audio & USB 2.0 Hub In Stock £449.33
CWSB StarTech.com HDMI Over Single Cat 5e / 6 Extender with Power Over Cable - 230 ft (70m) In Stock £210.56
CWSB StarTech.com HDMI Video Over IP Gigabit LAN Ethernet Extender Kit - 1080p In Stock £333.74
CWSB StarTech.com HDMI Video Over IP Gigabit LAN Ethernet Receiver for ST12MHDLAN - 1080p In Stock £185.25
CWSB StarTech.com 3.5in Black USB 3.0 External SATA III Hard Drive Enclosure with UASP for SATA 6 Gbps In Stock £41.26
CWSB StarTech.com 3.5in Silver USB 3.0 External SATA III Hard Drive Enclosure with UASP In Stock £34.68
CWSB StarTech.com HDMI Over CAT5/CAT6 Extender with Power Over Cable - 165 ft (50m) In Stock £101.44
CWSB StarTech.com 1 Port RS232 Serial to IP Ethernet Converter / Device Server - Aluminum In Stock £112.93
CWSB StarTech.com Gigabit Ethernet Fiber Media Converter with Open SFP Slot In Stock £109.25
CWSB StarTech.com USB 3.0 SATA III Hard Drive Docking Station SSD / HDD with UASP In Stock £38.66
CWSB StarTech.com HDMI Over CAT5e / CAT6 Extender with Power Over Cable - 330 ft (100m) In Stock £348.25
CWSB StarTech.com OAM Managed Gigabit Ethernet Fiber Media Converter - MM LC 550m - 802.3ah Compliant In Stock £145.83
CWSB StarTech.com 2 Port HDMI Switch w/ Automatic and Priority Switching - 1080p In Stock £56.59
CWSB StarTech.com 2X2 HDMI Matrix Switch w/ Automatic and Priority Switching 1080p In Stock £100.91
CWSB StarTech.com USB 3.0 & eSATA HDD Dock In Stock £50.64
CWSB StarTech.com 2-port Dual VGA KVM Switch In Stock £156.84
CWSB StarTech.com 4-port Dual VGA KVM Switch In Stock £207.93
CWSB StarTech.com DC Power Adapter - 9V, 2A In Stock £12.80
CWSB StarTech.com DC Power Adapter - 5V, 3A In Stock £12.88
CWSB StarTech.com GbE Fiber Media Converter 10km In Stock £200.42
CWSB StarTech.com GbE Fiber Media Converter 20km In Stock £184.47
CWSB StarTech.com HDBaseT Extender Kit - 4K In Stock £304.93
CWSB StarTech.com 2 Port Dual DP KVM Switch - 4K In Stock £251.16
CWSB StarTech.com DC Power Adapter - 12V, 2A In Stock £13.92
CWSB StarTech.com USB C to SATA Adapter Cable In Stock £40.42
CWSB StarTech.com 4 Port USB 3.0 Hub A to C & A In Stock £49.97
CWSB StarTech.com 4 Port USB-C Hub - C to C & A In Stock £51.63
Stock Status: In stock
