StarTech.com Composite?to VGA Video Converter?-?1920x1200?
Quicklinx: FJP1WS00 Mfr#: VID2VGATV3
This composite to VGA video converter provides a simple way to convert and scale composite and S-Video signals to VGA output, for use with computer monitors, projectors or HDTV sets.
Equipped with an on-screen display (OSD) menu and a toggle switch for simple configuration and selection of your video output settings, this compact S-Video to VGA video converter installs quickly and easily, for a true plug-and-play experience.
By using this AV to VGA adapter you'll be able to continue using your legacy equipment (VCR, DVD player, etc.) with your VGA display or monitor, ultimately saving the costs of upgrading your equipment. It's ideal for boardroom settings, medical imaging and watching old home videos on your VGA display or new HDTV.
The AV to VGA converter features an integrated video scaler circuit that dynamically converts the S-Video or composite video input signal, giving you multiple output resolutions to choose from, to ensure compatibility with your display or projector. It supports resolutions up to 1920x1200 @ 60Hz, so you can enjoy high-definition video without having to sacrifice picture quality.
StarTech.com Composite?to VGA Video Converter?-?1920x1200?-?Composite Video Scaler - S Video to VGA Adapter - video converter - black
Video converter
Max Resolution
1920 x 1200
1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x VGA - 15 pin HD D-Sub (HD-15)
5.5 cm x 6.1 cm x 2 cm
Enclosure Colour
Europe
Video converter
Max Resolution
1920 x 1200 at 60 Hz
1 x composite video input - RCA - female , 1 x S-video input - 4 pin mini-DIN - female , 1 x VGA - 15 pin HD D-Sub (HD-15) - female
USB powered
Video Output
Analogue Video Format
NTSC, PAL
1 x mini-USB to USB cable
5.5 cm
6.1 cm
2 cm
Shipping Width
13 cm
Shipping Depth
10.5 cm
Shipping Height
2.4 cm
Enclosure Colour
Europe
FJP1 StarTech.com USB Wall Charger 17W / 3.4A x2 In Stock £13.05
FJP1 StarTech.com 2x USB Wall Charger 17W / 3.4A In Stock £14.91
FJP1 StarTech.com DC Power Adapter - 5V, 3A In Stock £12.01
