StarTech.com Composite and S-Video to VGA Video Converter
Quicklinx: 4RY3WS00 Mfr#: VID2VGATV
Convert and scale a composite or S-video signal to work with a VGA monitor. This composite/S-video to VGA video converter scales and converts composite video, s-video, and YCbCr (RGB) video to VGA/HDTV - a simple solution for connecting non-VGA/HDTV enabled equipment to VGA or HDTV display devices like CRT monitors, VGA projectors, LCD displays and plasma displays.
The video converter automatically detects your source's input resolution and allows you to customize its output resolution and refresh rate through an easy to use on-screen-display menu - providing a convenient, easy-to-use way to get the most from your HD display.
StarTech.com Composite and S-Video to VGA Video Converter - video converter - 48 MB - black
Video converter
48 MB
1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x RGB input - 8 PIN mini-DIN , 1 x component video input - RCA x 3 (with adapter) , 1 x component video output - RCA x 3 (with adapter)
7.7 cm x 14.6 cm x 3 cm
Enclosure Colour
1-year warranty
P/N: SVA5M3NEUA
Video converter
1 x VGA output - 15 pin HD D-Sub (HD-15) - female , 1 x S-video input - 4 pin mini-DIN - female , 1 x composite video input - RCA - female , 1 x RGB input - 8 PIN mini-DIN - female , 1 x component video input - RCA x 3 (with adapter) - female , 1 x component video output - RCA x 3 (with adapter) - male
Size
48 MB
Video Output
Supported Display Graphics
VGA (640x480), XGA (1024x768), SVGA (800x600), SXGA (1280x1024), HDTV (1920x1080), HD (1280 x 720), 720x480, 1280x768, 720x576
Analogue Video Format
NTSC, PAL
1 x component video adapter , 1 x composite video cable - 91.44 cm , 1 x S-Video cable - 1.22 m , 1 x VGA cable - 1.22 m , 1 x VGA / component video adapter - 91.44 cm
7.7 cm
14.6 cm
3 cm
240 g
Enclosure Colour
1-year warranty
P/N: SVA5M3NEUA
4RY3 StarTech.com DC Power Adapter - 5V, 3A In Stock £12.01
4RY3 StarTech.com HDMI to RCA Converter Box In Stock £64.33
