StarTech.com S-Video or Composite to HDMI Converter with Audio - 720p - video converter - black
Quicklinx: FHLWWS00 Mfr#: VID2HDCON2
Hurry, only 1 left in stock!
£72.98 ex VAT
£87.57 inc VAT
This S-Video or composite to HDMI&#174 converter with audio lets you connect an S-Video or analog composite device, along with supporting RCA L/R audio, to your HDMI monitor or television.
Equipped with an on-screen display (OSD) menu and convenient selector switches for easy configuration, this compact S-Video or composite to HDMI video converter installs quickly and easily, for a true plug-and-play experience.
This HDMI upscaler is able to function with both NTSC and PAL systems, and offers support for output resolutions up to 720p to seamlessly integrate with almost any display.
By using this analog to HDMI converter you'll be able to continue using your legacy equipment (video camera, DVD player, etc.) with your HDMI display or monitor, ultimately saving the costs of upgrading your equipment. It's ideal for boardroom settings, medical imaging and watching old home videos on your HD display or television.
This AV (audio video) converter box features an integrated RCA L/R audio connection that combines the audio and video inputs into a single HDMI output, avoiding the hassle of running a separate audio cable to your destination display.
Video converter
Max Resolution
1280 x 720
1 x HDMI output - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - RCA x 2 , 1 x composite video input - RCA
7.1 cm x 15.5 cm x 2.3 cm
Enclosure Colour
Video converter
Max Resolution
1280 x 720 at 60 Hz
OnScreenDisplay (OSD), LED indicator
Video Output
Analogue Video Format
PAL, NTSC 3.58
AC 120/230 V
2.5 Watt
Power adapter
7.1 cm
15.5 cm
2.3 cm
252 g
Shipping Width
20 cm
Shipping Depth
25 cm
Shipping Height
6 cm
Shipping Weight
395 g
Enclosure Colour
45 °C
FHLW StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.62
FHLW StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £4.68
FHLW StarTech.com DC Power Adapter - 5V, 3A In Stock £11.71
