StarTech.com Component / VGA Video and Audio to HDMI Converter PC to HDMI 1920x1200
Quicklinx: 8GN6WS00 Mfr#: VGA2HD2
Type: AV Sender
13 in stock
£77.11 ex VAT
£92.53 inc VAT
Connect your VGA or Component video source to an HDMI display. The VGA2HD2 Component/VGA to HDMI Video Converter offers seamless conversion from an analog VGA or Component video source, such as a Computer, DVR, or DVD player, to a digital HDMI output.
The converter helps reduce equipment costs by eliminating the need to upgrade individual analog components, by offering a solution that converts an analog video source (RGB/YPbPr) for use with a digital HDMI display.
This versatile analog-digital converter not only supports resolutions up to 1920x1200 including high-definition 1080p, but also enables you to convert and combine an analog RCA audio source into its digital HDMI output signal.
StarTech.com Component / VGA Video and Audio to HDMI Converter - PC to HDMI - video converter - black
Video converter
1 x audio line-in - RCA x 2 , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI output - 19 pin HDMI Type A , 1 x component video input - RCA x 3 (on supplied cable)
7.6 cm x 3 cm x 9.2 cm
Enclosure Colour
United States
Video converter
1 x audio line-in - RCA x 2 - female , 1 x VGA input - 15 pin HD D-Sub (HD-15) - female , 1 x HDMI output - 19 pin HDMI Type A - female , 1 x component video input - RCA x 3 (on supplied cable) - male
1 x component video cable
FCC, RoHS
7.6 cm
3 cm
9.2 cm
190 g
Enclosure Colour
United States
20 - 90%
8GN6 StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £6.05
8GN6 StarTech.com 6 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £3.65
8GN6 StarTech.com 3 ft HD15 to Component RCA Breakout Cable Adapter - M/M In Stock £10.05
8GN6 StarTech.com Component / VGA Video and Audio to HDMI Converter PC to HDMI 1920x1200 In Stock £77.11
Type: AV Sender
Price Range Ex VAT: 50 - 100
