Connect your VGA or Component video source to an HDMI display. The VGA2HD2 Component/VGA to HDMI Video Converter offers seamless conversion from an analog VGA or Component video source, such as a Computer, DVR, or DVD player, to a digital HDMI output.
The converter helps reduce equipment costs by eliminating the need to upgrade individual analog components, by offering a solution that converts an analog video source (RGB/YPbPr) for use with a digital HDMI display.
This versatile analog-digital converter not only supports resolutions up to 1920x1200 including high-definition 1080p, but also enables you to convert and combine an analog RCA audio source into its digital HDMI output signal.
- StarTech.com Component (YPbPr) / VGA To HDMI Converter With Audio - PC to HDMI - resolutions up to 1080p (HDTV) and 1920 x 1200 (PC) (VGA2HD2) - video converter - black
- Video converter
- 1 x audio line-in - RCA x 2 , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI output - 19 pin HDMI Type A , 1 x component video input - RCA x 3 (on supplied cable)
- 7.6 cm x 3 cm x 9.2 cm
- Enclosure Colour
- Black
- Localisation
- United States
- 2-year warranty
- Video converter
- 1 x audio line-in - RCA x 2 - female , 1 x VGA input - 15 pin HD D-Sub (HD-15) - female , 1 x HDMI output - 19 pin HDMI Type A - female , 1 x component video input - RCA x 3 (on supplied cable) - male
- Cables Included
- 1 x component video cable
- FCC, RoHS
- 7.6 cm
- 3 cm
- 9.2 cm
- 190 g
- Enclosure Colour
- Black
- Localisation
- United States
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 20 - 90%
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.37 |
StarTech.com High Resolution VGA to Composite (RCA) or S-Video Converter - PC to TV | In Stock | £95.65 |
StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male | In Stock | £5.00 |
StarTech.com Component / VGA Video and Audio to HDMI Converter PC to HDMI 1920x1200 | In Stock | £90.94 |
StarTech.com VGA to HDMI Adapter with USB Audio & Power- Portable VGA to HDMI Converter 1080p | In Stock | £43.85 |
StarTech.com VGA to HDMI Scaler - 1920x1200 | In Stock | £207.80 |
StarTech.com 1080p VGA to RCA and S-Video Converter - USB Powered | In Stock | £44.36 |
StarTech.com 3 m (10 ft.) VGA to HDMI Adapter Cable with USB Audio | In Stock | £39.35 |
StarTech.com 2 m (6.6 ft.) VGA to HDMI Adapter Cable with USB Audio | In Stock | £32.05 |
