The SFP-10G-ZR-S-ST is a Cisco SFP-10G-ZR-S compatible fiber transceiver module that has been designed, programmed and tested to work with Cisco brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10GBase-ZR compliant networks, with a maximum distance of up to 80 km (49.7 mi).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com Cisco SFP-10G-ZR-S Compatible SFP+ Module, 10GBASE-ZR, 10GbE Single Mode (SMF) Fiber Optic Transceiver, 10GE Gigabit Ethernet SFP+ LC Connector, 80km, 1550nm, DDM, Cisco ASR9000 - Lifetime Warranty (SFP-10G-ZR-S-ST) - SFP+ transceiver module - 10GbE
- SFP+ transceiver module - LC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-ZR
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 1550 nm
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 80 km
- OEM Manufacturer Equivalent Part Number
- Cisco SFP-10G-ZR-S
- 5.84 cm x 1.39 cm x 1.37 cm
- 24 g
- Limited lifetime warranty
- Designed For
- Cisco 16, 4, 8, Generic Expansion Module, Unified Port Expansion Module; 250 Series; Catalyst 2360, Blade Switch 31XX, Switch Module 3110; Nexus 2148, 2232PP 10, 22XX, 30XX, 31XX, 3548, 4001, 50XX, 55XX, 7000, 7000 48, 8, 93180, 93XX; ONE Nexus 55XX; UCS 2104, 2208, 6140, 62XX, C4200
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-ZR
- 10GbE
- 10 Gbps
- 1550 nm
- 80 km
- Digital Diagnostics Monitoring (DDM)
- 1 x Ethernet 10GBase-ZR - LC single-mode female x 2
- MTBF
- 426,514,897 hours
- MSA
- 1 Watt
- 5.84 cm
- 1.39 cm
- 1.37 cm
- 24 g
- Shipping Width
- 9 cm
- Shipping Depth
- 11.5 cm
- Shipping Height
- 3.1 cm
- Shipping Weight
- 50 g
- Limited warranty - lifetime
- Designed For
- Cisco 16-port 1/10GE Ethernet/FCoE module, 4-port 10 GE/4-port 4Gb FC, 8-Port Fibre Channel plus 8-Port 1 and 10 Gigabit Ethernet and FCoE Module, Generic Expansion Module, Unified Port Expansion Module , Cisco 250 Series SG250X-48P , Cisco Catalyst 2360-48TD-S, Blade Switch 3120X for HP, Blade Switch 3130X for Dell M1000e with IP Base, Switch Module 3110X for IBM BladeCenter w/ IP Base , Cisco Nexus 2148T Fabric Extender, 2224TP Fabric Extender, 2232PP 10GE Fabric Extender, 2232TM Fabric Extender, 2248TP GE Fabric Extender, 2248TP-E GE Fabric Extender, 3048 Reversed Airflow, 3048 Reversed Airflow LAN Enterprise License Bundle, 3048 Standard Airflow LAN Enterprise License Bundle, 3048TP-1GE, 3064-E, 3064PQ, 3064PQ Front-to-Back Airflow LAN Enterprise License Bundle, 3064-X, 3132Q, 3132Q-X, 3172PQ, 3548, 3548x, 4001I Switch Module for IBM Blade Center, 5010, 5010 OSM version, 5020, 5548 Storage Solutions Bundle, 5548P, 5548UP, 5596UP, 7000 48-Port 1 and 10 Gigabit Ethernet F2-Series Module, 7000 Enhanced F2-Series 48-Port Fiber 1 and 10 Gigabit Ethernet Module, 7000 Series 32-Port 1 and 10 Gigabit Ethernet Module, 7000 Series 32-Port 10 Gigabit Ethernet Module with XL Option, 7000 Series 32-Port 10Gb Ethernet Module with 80Gbps Fabric, 8-Port 10 Gigabit Ethernet Module with XL Option, 93180YC-FX, 9336C-FX2, 9372PX-E , Cisco ONE Nexus 5548UP, 5596UP , Cisco UCS 2104XP Fabric Extender, 2208XP Fabric Extender, 6140XP Fabric Interconnect, 6200 Series 16-port 10Gb Unified Port Expansion Module, 6248UP Fabric Interconnect, C4200 Rack Server Chassis
