Our checkout area is closed for maintenance, but should be back online soon. We apologise for any inconvenience caused
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC – 550m (Mini-GBIC)
Quicklinx: 8GTWWS00 Mfr#: SFPGLCSXMMST
Type: Modules
16 In Stock
£24.09 ex VAT
£28.90 inc VAT
Add, replace or upgrade SFP modules on Gigabit fiber equipment. The SFPGLCSXMMST Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC - 550m (1804 ft) is built to comply with MSA (Multi-Sourcing Agreement) standards to offer a cost-effective way to add, replace or upgrade a Multimode LC port on your Gigabit fiber networking equipment or fiber media converter.
Supporting data rates up to 1.25 Gbps, this LC Mini-GBIC module can be installed into any fiber networking device with an MSA or Cisco compliant SFP port. Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install the module without interrupting network traffic or requiring a device reboot.
This 850nm multi-mode SFP module is compatible with the Cisco GLC-SX-MM transceiver. Also a perfect accessory for the StarTech.com PCI Express Open SFP NIC (PEX1000SFP), or Gigabit POE Open SFP Media Converter (ET1110PSE) products.
  • Reliable connectivity
    This SFP transceiver module provides effective Ethernet 1000Base-SX connectivity, ensuring stable and high-speed data transfer for network devices.
  • Versatile environmental performance
    Designed for a broad temperature range, this module can operate in both cool and warm environments while maintaining functionality.
  • Compliance with standards
    The module complies with standards, including IEEE 802.3z, UL, FCC, RoHS, and MSA, enhancing compatibility and safety for network applications.
  • Compact plug-in design
    Featuring a small form factor, the module can be easily plugged into an SFP slot, simplifying deployment and integration in various networking setups.
  • Support for multimode fiber
    Optimized for paired with LC multimode fiber, it provides excellent signal quality and transmission distance for network installations.
StarTech.com Cisco GLC-SX-MM Compatible SFP Module, 1000BASE-SX, 1GbE Multimode Fiber MMF Optic Transceiver, Gigabit Ethernet SFP, LC Connector, 550m, 850nm, Cisco IE3400, IE3300, IE3200 (SFPGLCSXMMST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1.25 Gbps
Optical Wave Length
850 nm
1GbE
Max Transfer Distance
550 m
1.2 cm x 6 cm x 1 cm
16 g
P/N: ET91000SFP2, ET91000SFP2C, IES101002SFP, MCM1110SFP, PEX1000SFP2
Plug-in module
Wired
Cabling Type
1000Base-SX
1GbE
Data Transfer Rate
1.25 Gbps
Optical Wave Length
850 nm
550 m
Full duplex capability, half duplex mode
IEEE 802.3z
1 x Ethernet 1000Base-SX - LC multi-mode x 2
Compatible Slots
1 x SFP (mini-GBIC)
UL, FCC, RoHS, MSA
1.2 cm
6 cm
1 cm
16 g
Limited warranty - lifetime
70 °C
30 - 70%
8GTW StarTech.com Gb MM SFP Fiber Transceiver In Stock £35.36
8GTW StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £14.35
8GTW StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £24.07
8GTW StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £15.49
8GTW StarTech.com 5m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £18.84
8GTW StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-SC In Stock £16.00
8GTW StarTech.com 3m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £16.65
8GTW StarTech.com Cisco Compatible 100 Mbps Fiber SFP Transceiver Module MM LC w/ DDM - 2 km (Mini-GBIC) In Stock £36.73
8GTW StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC) In Stock £40.45
8GTW StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC – 550m (Mini-GBIC) In Stock £24.09
8GTW StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC In Stock £142.63
8GTW StarTech.com Fiber Media Converter - Open In Stock £43.33
8GTW StarTech.com Gigabit Fiber SFP - 10 Pack In Stock £228.89
8GTW StarTech.com Gigabit Fiber SFP - 10 Pack In Stock £223.48
8GTW StarTech.com Gb Fiber SFP - Cisco Compatible In Stock £37.59
8GTW StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports In Stock £335.67
Type: Modules
