Add up to four 1GbE SFP modules to a PCI Express (PCIe) 2.0 x2 (or higher) slot in an IT Administrator workstation or server backplane, using this 4-Port SFP Network Controller.
High Performance Intel Chipset
The network controller features an Intel I350 chip known for its reliability and high-performance capabilities, offering low-latency and low CPU utilization, ensuring smooth and efficient network data transfer, which is critical for business applications and services. Support for VMDq, SR-IOV, and Intel VT-c technologies allow for enhanced virtual machine performance, reduced CPU overhead, and improved network virtualization capabilities. The PCIe network card supports PXE boot, enabling centralized operating system deployment and updates. It also features 9K jumbo frame support, reducing packet overhead for improved data transmission efficiency. VLAN tagging support allows for efficient network management and segmentation. -
Hardware and Operating System Compatibility
The network interface controller connects to an available x2 PCI Express 2.0 (or higher) expansion slot. It is compatible with Windows Server 2012 and newer, Windows 10 and newer, Linux, VMware ESXi 7.x, and Microsoft Hyper-V. This NIC is compatible with both MSA-compliant and branded 1GB SFP modules, as well as direct attach copper cables (DACC). -
Flexible Network Connections
The card features four SFP slots for interchangeable SFP modules. Select fiber transceiver modules that best suit the network needs of the application, based on the distance and connector type. StarTech.com offers a wide variety of SFP transceiver modules to meet many GbE network applications.
- Startech 4-Port GbE SFP Network Card, PCIe 2.0 x2, Intel I350-AM4 4x 1GbE Controller, 1000BASE Copper/Fiber Optic, Quad-Port Gigabit Ethernet NIC, Desktop/Server Backplanes - Windows and Linux Compatible (P041GI-NETWORK-CARD) - network adapter - PCIe 2.0 x2 - Gigabit SFP x 4
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express 2.0 x2
- PCI Specification Revision
- PCIe 2.0, PCIe 2.1
- Ports
- Gigabit SFP x 4
- 1 cm x 16.7 cm x 8.3 cm
- Cabling Type
- Ethernet 1000Base-LX, Ethernet 1000Base-SX, Ethernet 1000Base-T, Ethernet 1000Base-KX
- Data Link Protocol
- 1GbE
- Data Transfer Rate
- 1 Gbps
- Capacity
- Jumbo frame size: 9000
- TCP/IP, UDP/IP, IPv4, IPv6
- Processor
- Intel I350-AM4
- IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3ap, IEEE 802.3az, IEEE 802.11ax
- Black
- System Requirements
- Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Hyper-V Server, Microsoft Windows Server 2019, Microsoft Windows Server 2022, Microsoft Windows 10 / 11, VMware ESXi 7.x, Linux 2.4.x or later (LTS versions only)
- 2-year warranty
- Network adapter
- Form Factor
- Plug-in card
- Ports
- Gigabit SFP x 4
- Connectivity Technology
- Wired
- Cabling Type
- Gigabit Ethernet
- 1 Gbps
- Capacity
- Status Indicators
- Link/activity, link/speed
- Full duplex capability, VMDq, SR-IOV, VT-c, Link Aggregation, DDM, EEE, VLAN Tagging, promiscuous mode, with heat sink, Auto MDIX, PXE boot, bus powered
Processor / Memory
- Processor
- Intel I350-AM4
- 4 x 1000Base-LX/SX - SFP (mini-GBIC)
- FCC, WEEE, MSA, EMI
- Black
- 3.5 watt
- OS Required
- 1 cm
- 16.7 cm
- 8.3 cm
- Shipping Width
- 3.8 cm
- Shipping Depth
- 20.7 cm
- Shipping Height
- 14.4 cm
- Shipping Weight
- 135 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 5 - 90% RH (non-condensing)
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC) | In Stock | £40.45 |
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC w/ DDM – 550m (Mini-GBIC) | In Stock | £24.09 |
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC – 550m (Mini-GBIC) | In Stock | £24.09 |
StarTech.com 1-Port GbE SFP Network Card | In Stock | £92.63 |
StarTech.com 2-Port GbE SFP Network Card | In Stock | £116.36 |
