StarTech.com CFast Card Reader - USB 3.0
Quicklinx: CVR6WS00 Mfr#: CFASTRWU3
Supported Formats: CompactFlash Card type II
Interface: USB 3.0
Hurry, only 2 left in stock!
£22.18 ex VAT
£26.61 inc VAT
Quickly access or back up photos and video from your CFast 2.0 memory cards to your tablet, laptop, or computer. Quickly download, view and back up photos and videos on your CFast memory cards, with this CFast card reader/writer. Offload or back up files wherever you go, out in the field or back at the studio.
Take advantage of the fast performance of USB 3.0 (5Gbps) when you download high-resolution photos and full HD videos from your DSLR camera or camcorder to your laptop, tablet or desktop computer. Save valuable time daily and achieve greater work-flow efficiency when accessing, transferring, and backing up files to a computer.
Use the card reader/writer wherever you go to access your photos and videos quickly. Featuring a compact, lightweight design and integrated cable, the card reader is conveniently small for portable use, or for use with a computer in a fixed location. It tucks easily into a carrying case to take from studio to field. It's also USB powered, so there is no external power required.
The card reader/writer features durable, solid construction to withstand the rigors of travel. The built-in cable means one less thing to remember to carry along.
Ideal for photographers and videographers, the card reader/writer is designed for ease of use, with plug-and-play functionality for CFast 2.0 memory cards to save time daily and work more efficiently. To enhance your productivity, access many CFast 2.0 or 1.0 cards simultaneously through the use of multiple adapter cables.
Setting up is easy. The CFast card reader/writer requires no additional drivers or software, and is compatible with most operating systems including Windows, Mac and Linux.
  • High performance access to files
  • Compact design for easy portability
    Use the card reader/writer wherever you go to access your photos and videos quickly. Featuring a compact, lightweight design and integrated cable, the card reader is conveniently small for portable use, or for use with a computer in a fixed location. It tucks easily into a carrying case to take from studio to field. It's also USB powered, so there is no external power required. The card reader/writer features durable, solid construction to withstand the rigors of travel. The built-in cable means one less thing to remember to carry along.
  • Easy access to CFast storage
    Ideal for photographers and videographers, the card reader/writer is designed for ease of use, with plug-and-play functionality for CFast 2.0 memory cards to save time daily and work more efficiently. To enhance your productivity, access many CFast 2.0 or 1.0 cards simultaneously through the use of multiple adapter cables. Setting up is easy. The CFast card reader/writer requires no additional drivers or software, and is compatible with most operating systems including Windows, Mac and Linux. The CFASTRWU3 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com CFast Card Reader - USB 3.0 - USB Powered - UASP - Memory Card Reader - Portable CFast 2.0 Reader / Writer (CFASTRWU3) - card reader - USB 3.0
Card reader - external
Supported Memory Cards
Host Interface
USB 3.0
Silver
Power indicator
Host Interface
USB 3.0
Silver
Power indicator
5.8 cm
25.6 cm
1.47 cm
42.2 g
Memory Card
(max)
Required Ports
1 x 9 pin USB Type A
Plug and Play, FCC, RoHS, WEEE, RCM
CVR6 StarTech.com 5 ft Desktop SuperSpeed USB 3.0 Extension Cable - A to A M/F In Stock £12.06
CVR6 StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP In Stock £34.16
CVR6 StarTech.com 1m Blue SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.53
CVR6 StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.74
CVR6 StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - LP4 Power In Stock £22.94
CVR6 StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels In Stock £78.58
CVR6 StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable In Stock £8.04
CVR6 StarTech.com 5 ft Black Desktop SuperSpeed USB 3.0 Extension Cable - A to A M/F In Stock £11.79
CVR6 StarTech.com USB 3.0 to eSATA HDD / SSD / ODD Adapter Cable - 3ft eSATA Hard Drive to USB 3.0 Cable In Stock £23.52
CVR6 StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £7.23
CVR6 StarTech.com 4 Port PCIe USB 3.0 Card In Stock £23.69
CVR6 StarTech.com USB 3.1 Gen 2 Adapter Cable In Stock £15.16
CVR6 StarTech.com USB 3.1 Adapter Cable w/ USB-C In Stock £16.51
CVR6 StarTech.com Flash Card Reader - USB-C In Stock £24.07
CVR6 StarTech.com CFast Card Reader - USB 3.0 In Stock £22.18
CVR6 StarTech.com USB 3.0 SD/microSD Card Reader In Stock £9.49
CVR6 StarTech.com CFexpress Type B Card Reader In Stock £19.01
CVR6 StarTech.com SD Express Card Reader In Stock £31.89
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: CVR6 050957
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £8.60
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Interface: USB 3.0
Stock Status: Used Stock
