StarTech.com SD Express Card Reader
Quicklinx: J1KKWS00 Mfr#: 1B-USB-C-SDE-ADAPTER
£31.70 ex VAT
£38.04 inc VAT
The StarTech.com USB-C SD Express Card Reader is a versatile device designed for seamless connectivity. Featuring an external aluminum housing, this card reader is durable and lightweight, making it easy to carry for on-the-go use. With its USB-C 3.2 Gen 2 interface, it supports data transfer speeds of up to 10 Gbps, enabling quick access to your files and simplifying data management.
This card reader supports both SDHC and SDXC memory cards, allowing for compatibility with a variety of devices. Furthermore, it supports microSD and miniSD formats with the use of an adapter, providing additional flexibility. Bus-powered for convenience, this reader operates without the need for external power, ensuring that it is ready when you are.
  • Efficient data transfer
    With support for USB-C 3.2 Gen 2, this card reader offers data transfer speeds of up to 10 Gbps, reducing waiting times and enhancing productivity.
  • Broad memory compatibility
    This card reader is compatible with SDHC and SDXC memory cards, and with an adapter, it can also work with microSD and miniSD formats, ensuring versatility for various users.
  • Portable design
    The lightweight and compact design of the aluminum housing makes it ideal for travel, fitting easily into bags or pockets for on-the-go access to your memory cards.
  • Bus-powered convenience
    This card reader is bus-powered, meaning it draws power directly from the USB-C connection, eliminating the need for additional power sources and making it easy to use anywhere.
StarTech.com USB-C SD Express Card Reader, USB 10Gbps, Portable Memory Card Reader, USB Type-C to Secure Digital 7.1 Adapter, Works with Any Operating System - card reader - USB-C 3.2 Gen 2
Card reader - external
Supported Memory Cards
SDHC Memory Card, SDXC Memory Card
Host Interface
USB-C 3.2 Gen 2
Aluminium housing, bus-powered, up to 10 Gbps data transfer
Supported with Optional Adapter
microSD, miniSD
Host Interface
USB-C 3.2 Gen 2
5.4 cm
27.4 cm
1.4 cm
60 g
Memory Card
(max)
Required Ports
1 x 24 pin USB-C
Apple MacOS, Google Chrome OS, Microsoft Windows, Linux
Shipping Width
14.2 cm
Shipping Height
3 cm
Shipping Weight
63 g
J1KK StarTech.com CFexpress Type B Card Reader In Stock £19.18
