StarTech.com Ceiling TV Mount - Long Pole
Quicklinx: D0ZPWS00 Mfr#: FPCEILPTBLP
Type: Bracket
13 In Stock
£136.15 ex VAT
£163.38 inc VAT
Securely mount your flat-panel TV to a ceiling or overhead structure, and customize your viewing angle with easy position adjustments. Now, you can suspend your flat-screen television in an area with a high ceiling, for optimal viewing. This flat-screen TV ceiling mount supports VESA mount compatible TVs from 32" to 70" in size. It features a long pole that extends from 8.2 to 9.84 ft. (2.5 to 3 m), making it easy to adjust the distance from the ceiling. Its full-motion design lets you change your screen position and angle.
The ceiling TV mount lets you mount your flat-panel LCD, LED or plasma TV in a prominent area. It's ideal for use in lobbies, entrances or other areas with high ceilings.
The heavy-duty steel TV ceiling mount is compatible with a wide selection of TVs, able to securely support a 32" to 70" display, with a weight capacity of up to 110 lb. (50 kg). To keep the cables concealed and organized, you simply run them through the cable management channel inside of the pole, exiting near the top.
With an adjustable length, the telescopic-style pole makes it easy to mount your display at the desired distance from the ceiling and works well with a range of ceiling heights. The robust steel pole can extend from 8.2 to 9.84 ft. (2.5 to 3 m), with a total lift (height extension) of 19.6" (.5 m).
The flat-screen TV ceiling mount is designed to accommodate a wide variety of ceiling types. The ceiling mount swivels, so you can adjust the mount to work with virtually any type of ceiling for level viewing, including sloped ceilings (up to 60°), and pitched or horizontal (flat) ceilings.
You can adjust your flat-screen TV to create a comfortable viewing angle, by tilting it (up to -25°) down towards your audience for optimum visibility. The full-motion mount lets you swivel your display around the pole + 180° / - 180°, without using tools, which makes it easy to set up for viewing from any direction you choose.
The hook-and-mount design of the TV ceiling mount makes setup fast and easy. You simply attach the vertical brackets, with built-in hooks, to the back of your TV. Once the brackets are attached, you can hang your TV securely onto the ceiling mount. The preset leveling adjustments ensure ideal positioning after hanging.
  • Adjustable Height
    With a telescopic pole, the TV mount lets you suspend a display at your desired distance from the ceiling. This works well with a range of ceiling heights. The steel pole can extend from 8.2 to 9.84 ft. (2.5 to 3 m), with a total lift (height extension) of 19.6" (.5 m).
  • Swivels to Suit Your Ceiling
    The flat-screen ceiling mount accommodates a wide variety of ceiling types. You can swivel the TV to work with virtually any type of ceiling for level viewing, including sloped ceilings (up to 60 degrees), and pitched or horizontal (flat) ceilings.
  • Viewable from Any Direction
    You can adjust your TV to create a comfortable viewing angle, by tilting it up to -25 degrees down towards your audience for optimum visibility. Plus, the full-motion mount lets you swivel your display around the pole + 180 / - 180 degrees, without using tools.
  • Hook-and-Mount Design
    Simply attach the included vertical brackets, with built-in hooks, to the back of your TV. Once attached, hang your TV securely onto the ceiling mount. The +/-3 degree post-installation leveling adjustments ensure ideal positioning after hanging. FPCEILPTBLP is backed by a StarTech.com 5-year warranty and free lifetime technical support.
StarTech.com Ceiling TV Mount - 8.2' to 9.8' Long Pole - Full Motion - Supports Displays 32" to 75" - For VESA Mount Compatible TVs (FPCEILPTBLP) bracket - for flat panel - black
Bracket - ceiling mountable
43.5 cm x 68 cm x 3.218 cm
Adjustable Height
250-300 cm
Tilt
0° to 25°
Pan
-180° to 180°
Lift
50 cm
Rotation
360°
Adjustments
Height, pan, tilt, swivel, rotation
10 kg
Recommended Use
Flat panel
Recommended Display Size
32"-70"
VESA Mounting Interface
200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 300 mm
Max Load Weight
50 kg
Material
Heavy duty steel
Package Content
4 x M5x14 screws, 4 x M6x14 screws, 4 x M6x30 screws, 4 x M8x30 screws, 4 x washers, 8 x spacers (small), 4 x concrete anchors, hex key, 4 x M8x50 screws, 8 x spacers (big), wrench, 4 x nuts, 4 x screws, 4 x rectangular washers, ceiling mount and pole, middle pole, lower pole, TV mount, 2 x vertical brackets, horizontal bracket, 2 x M8x55 screws, 2 x M8x60 screws, mounting template
5-year warranty
P/N: HDMIPLATE
43.5 cm
68 cm
3.218 cm
Adjustable Height
250-300 cm
10 kg
Material
Heavy duty steel
Package Content
AV Furniture
Bracket
Recommended Use
Flat panel
Placing / Mounting
Ceiling mountable
Cable Management
Integrated cable management
32"-70"
Tilt
0° to 25°
Pan
-180° to 180°
Lift
50 cm
Rotation
360°
Adjustments
Max Load Weight
50 kg
Limited warranty - 5 years
P/N: HDMIPLATE
D0ZP StarTech.com SPDIF Digital Coaxial or Toslink Optical to Stereo RCA Audio Converter In Stock £32.94
D0ZP StarTech.com 15 ft Thin Toslink Digital Optical SPDIF Audio Cable In Stock £5.45
D0ZP StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £16.00
D0ZP StarTech.com Flat-Screen TV Ceiling Mount In Stock £109.26
D0ZP StarTech.com Ceiling TV Mount - Steel In Stock £102.58
D0ZP StarTech.com Ceiling TV Mount - Long Pole In Stock £136.15
D0ZP StarTech.com 10m CL2 Active HDMI Cable - 4K In Stock £81.45
D0ZP StarTech.com Ceiling TV Mount, Back-to-Back In Stock £209.05
Type: Bracket
