This cable-management spine neatly routes cables from the floor to the bottom surface of your desk or table, with four separate channels for computer or electrical cords. It's an easy and practical way to protect your workstation cables, while creating an attractive, clutter-free work area.
The weighted base sits on the floor to provide a stable base to route your cables. You simply slide each cable through the slot into one of four channels within the cable manager, to keep cables organized and help prevent trips over cables on the floor.
The flexible cable management spine bends and moves, providing protection and strain relief for your cables. The cable manager features a modular design, with segments that snap together, allowing you to adjust the length to suit your needs.
The cable manager includes a mounting plate that attaches to the underside of your desk, table or counter. It keeps the cable management-spine securely in place.
Routes cables neatly from floor to desk
The weighted base sits on the floor to provide a stable base to route your cables. You simply slide each cable through the slot into one of four channels within the cable manager, to keep cables organized and help prevent trips over cables on the floor. -
Easily adjusts to your needs
- StarTech.com Spine Cable Management - Weighted Base Plate - Cord Cover - Cable Organizer - Cord Protector - Cable Raceway (CMVBMOD) - cable organizer
- Product Type
- Cable organizer
- Placing / Mounting
- Desk mountable
- 10.95 cm x 12.9 cm
- Length
- 1.29 m
- 1.4 kg
- Product Material
- Plastic, steel
- Silver
- 5-year warranty
- Product Type
- Cable organizer
- Desk mountable
- Product Material
- Plastic, steel
- 10.95 cm
- 12.9 cm
- Length
- 1.29 m
- 1.4 kg
- Enclosure Colour
- Silver
- Mounting Kit
- Included
- Adjustable height
- Limited warranty - 5 years
StarTech.com Cable Management Sleeve - 2 m | In Stock | £10.03 |
StarTech.com Cable Management Sleeve - Spiral - Expandable - 25mm x 2.5m | In Stock | £13.72 |
StarTech.com Cable Management Sleeve - Spiral - Expandable - 45mm x 2.5m | In Stock | £13.92 |
StarTech.com Cable Management Sleeve - Spiral - Expandable - 25mm x 1.5m | In Stock | £7.41 |
StarTech.com Cable Management Spine
