Organize your workstation cables with this adjustable cable manager, and trim the fabric to your desired length. This flexible and lightweight cable-management sleeve, made of polyester and nylon fabric, provides an easy and inexpensive solution to cable clutter. Use it to keep cables organized behind your computer monitor, while still providing access to cables when needed.
Simply open the rolled fabric to guide your cables through. The flexible sleeve automatically recoils to wrap around your cables. It can also expand to cover additional cables as needed. There are no tools required, and the cables do not need to be disconnected from the computer to be inserted into the cable-management sleeve.
Using sharp scissors, you can cut the cable-management sleeve to your desired length, to fit neatly under your desk or table, or behind your media center.
Durable construction
The cable management sleeve is crafted from a blend of nylon and polyester, ensuring it can withstand daily use while protecting your cables. -
Flexible size
This sleeve is designed to accommodate cables of different sizes, making it versatile for various applications in home and office environments.
- StarTech.com 6.5' (2m) Cable Management Sleeve, Flexible Coiled Cable Wrap, 1.0-1.5" dia. Expandable Sleeve, Polyester Cord Manager/Protector/Concealer, Black Trimmable Cable Organizer - Flame Resistant UL94-V0 - cable sleeving kit
- Product Type
- Cable sleeving kit
- Black
- Product Material
- Nylon, polyester
- 2.5 cm 2.5 cm
- Length
- 2 m
- 85 g
- 2-year warranty
- Product Type
- Product Material
- Nylon, polyester
- 2.5 cm
- 2.5 cm
- Length
- 2 m
- 85 g
- Black
- Limited warranty: - 2 years
StarTech.com Cable Management Spine | In Stock | £14.48 |
StarTech.com Cable Management Sleeve - Spiral - Expandable - 25mm x 2.5m | In Stock | £13.72 |
StarTech.com Cable Management Sleeve - Spiral - Expandable - 45mm x 2.5m | In Stock | £13.92 |
StarTech.com Cable Management Sleeve - Spiral - Expandable - 25mm x 1.5m | In Stock | £7.41 |
StarTech.com Rack Cable Management D-Ring | In Stock | £16.74 |
