Quicklinx: CZCYWS00 Mfr#: CMVBMOD
Select:
£14.48 ex VAT
£17.37 inc VAT
This cable-management spine neatly routes cables from the floor to the bottom surface of your desk or table, with four separate channels for computer or electrical cords. It's an easy and practical way to protect your workstation cables, while creating an attractive, clutter-free work area.
The weighted base sits on the floor to provide a stable base to route your cables. You simply slide each cable through the slot into one of four channels within the cable manager, to keep cables organized and help prevent trips over cables on the floor.
The flexible cable management spine bends and moves, providing protection and strain relief for your cables. The cable manager features a modular design, with segments that snap together, allowing you to adjust the length to suit your needs.
The cable manager includes a mounting plate that attaches to the underside of your desk, table or counter. It keeps the cable management-spine securely in place.
  • Routes cables neatly from floor to desk
  • Easily adjusts to your needs
StarTech.com Spine Cable Management - Weighted Base Plate - Cord Cover - Cable Organizer - Cord Protector - Cable Raceway (CMVBMOD) - cable organizer
Cable organizer
Placing / Mounting
Desk mountable
10.95 cm x 12.9 cm
Length
1.29 m
1.4 kg
Product Material
Plastic, steel
Silver
5-year warranty
Cable organizer
Placing / Mounting
Desk mountable
Product Material
Plastic, steel
10.95 cm
12.9 cm
Length
1.29 m
1.4 kg
Enclosure Colour
Silver
Mounting Kit
Included
Adjustable height
Limited warranty - 5 years
CZCY StarTech.com Cable Management Sleeve - 2 m In Stock £10.03
CZCY StarTech.com Cable Management Sleeve - Spiral - Expandable - 45mm x 2.5m In Stock £13.92
CZCY StarTech.com Cable Management Sleeve - Spiral - Expandable - 25mm x 1.5m In Stock £8.84
