The 40G-QSFP-SR4-ST is a Brocade 40G-QSFP-SR4compatible fiber transceiver module that has been designed, programmed and tested to work with Brocade brand switches and routers. It delivers dependable 40 GbE connectivity over fiber cable, for 40GBase-SR4 compliant networks, with a maximum distance of up to 150 m (492 ft.).
This QSFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com Brocade 40G-QSFP-SR4 Compatible QSFP+ Module, 40GBASE-SR4, 40GbE Multimode Fiber MMF Optic Transceiver, 40GE Gigabit Ethernet QSFP+, MPO Connector, 150m, 850nm, DDM, Mini GBIC - Lifetime Warranty (40G-QSFP-SR4-ST) - QSFP+ transceiver module - 40GbE
- QSFP+ transceiver module - MPO multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 40GBASE-SR4
- Data Transfer Rate
- 40 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- 40GbE
- Max Transfer Distance
- 150 m
- OEM Manufacturer Equivalent Part Number
- Brocade 40G-QSFP-SR4
- 12.2 cm x 1.86 cm x 0.85 cm
- 37.5 g
- Limited lifetime warranty
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 40GBASE-SR4
- 40GbE
- 40 Gbps
- 850 nm
- 150 m
- Digital Diagnostics Monitoring (DDM)
- 1 x Ethernet 40GBASE-SR4 - MPO multi-mode female
- MTBF
- 244,610,583 hours
- FCC, MSA
- 12.2 cm
- 1.86 cm
- 0.85 cm
- 37.5 g
- Shipping Width
- 9 cm
- Shipping Depth
- 11.5 cm
- Shipping Height
- 3.1 cm
- Shipping Weight
- 50 g
- Limited warranty - lifetime
