Add a sturdy, fixed shelf into almost any server rack or cabinet. The Black CABSHELF Standard Universal Server Rack Cabinet Shelf helps to efficiently organize your mission critical computer hardware and accessories by adding a fixed shelf with the capacity to hold up to 20 kg (44 lbs).
Universally mountable in any standard front mount 19" server rack or cabinet, the rack shelf is constructed of sturdy, cold-rolled steel for long-term durability.
- StarTech.com 2U Server Rack Mount Shelf - 15.7in Deep Steel Universal Cantilever Tray for 19" Network & AV Equipment Rack/ Cabinet - 44lbs (CABSHELF) rack shelf
- Product Type
- Rack shelf
- Limited lifetime warranty
- Designed For
- P/N: 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, CABSCRWM520, CABSCRWM620, CABSCRWS1224, RK1224WALHM, RK1232WALHM, RK1233BKM, RK12WALHM, RK1520WALHM, RK1820WALHM, RK1833BKM, RK2433BKM, RK2537BKM, RK2620WALHM, RK4236BKB, RK4242BK24, RK4242BK30, RK616WALM, RK8OD, RK920WALM, RK960CP, RK9WALM, RKQMCAB12V2
- Product Type
- Rack shelf
- Limited warranty - lifetime
- Designed For
- P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, CAB1019WALL, CABCAGENUTS6, CABSCREWM5, CABSCREWM52, CABSCREWM6, CABSCREWM62, CABSCREWS, CABSCREWSM6, CABSCRWM520, CABSCRWM620, CABSCRWS1224, RK1219SIDEM, RK1219WALH, RK1219WALHM, RK1219WALL, RK1224WALHM, RK1232WALHM, RK1233BKM, RK1236BKF, RK12OD, RK12WALHM, RK1520WALHM, RK1820WALHM, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK2620WALHM, RK4236BK, RK4236BKB, RK4236BKNS, RK4242BK, RK4242BK24, RK4242BK30, RK4242BKNS, RK616WALM, RK812WALLOA, RK819SIDEM, RK8OD, RK920WALM, RK960CP, RK9WALM, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg | In Stock | £78.43 |
StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £27.10 |
StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg | In Stock | £86.00 |
StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg | In Stock | £63.29 |
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg | In Stock | £80.98 |
StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg | In Stock | £39.49 |
StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg | In Stock | £25.99 |
