StarTech.com Black Standard Universal Server Rack Cabinet Shelf
Quicklinx: 7B5BWS00 Mfr#: CABSHELF
Product Type: Rack shelf, Rack shelf
16 In Stock
£30.71 ex VAT
£36.85 inc VAT
Add a sturdy, fixed shelf into almost any server rack or cabinet. The Black CABSHELF Standard Universal Server Rack Cabinet Shelf helps to efficiently organize your mission critical computer hardware and accessories by adding a fixed shelf with the capacity to hold up to 20 kg (44 lbs).
Universally mountable in any standard front mount 19" server rack or cabinet, the rack shelf is constructed of sturdy, cold-rolled steel for long-term durability.
StarTech.com 2U Fixed Server Rack Mount Shelf, 16in Deep Steel Universal Cantilever Tray for 19" AV/Data/Network Equipment Rack with Cage Nuts & Screws, 44lbs Weight Capacity, 60" Deep - 2U Network Rack Shelf (CABSHELF) - rack shelf
Rack shelf
P/N: CABSCRWM620, CABSCRWS1224, RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RACK-24U-20-WALL-OA, RK1224WALHM, RK1232WALHM, RK12OD2, RK12WALHM, RK1520WALHM, RK1820WALHM, RK2433BKM, RK2537BKM, RK2620WALHM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK616WALM, RK920WALM, RK9WALM, RKQMCAB12V2
Rack shelf
Limited warranty: - lifetime
P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, CAB1019WALL, CABCAGENUTS6, CABSCREWM5, CABSCREWM52, CABSCREWM6, CABSCREWM62, CABSCREWS, CABSCREWSM6, CABSCRWM520, CABSCRWM620, CABSCRWS1224, RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RACK-24U-20-WALL-OA, RK1219SIDEM, RK1219WALH, RK1219WALHM, RK1219WALL, RK1224WALHM, RK1232WALHM, RK1233BKM, RK1236BKF, RK12OD, RK12OD2, RK12WALHM, RK1520WALHM, RK1820WALHM, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK2620WALHM, RK3236BKF, RK4236BK, RK4236BKB, RK4236BKNS, RK4242BK, RK4242BK24, RK4242BK30, RK4242BKNS, RK616WALM, RK812WALLOA, RK819SIDEM, RK8OD, RK920WALM, RK960CP, RK9WALM, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
7B5B StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £94.63
7B5B StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £30.71
7B5B StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £8.54
7B5B StarTech.com 2U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £11.53
7B5B StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £25.30
7B5B StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £86.88
7B5B StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £74.28
7B5B StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £81.75
7B5B StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £56.70
7B5B StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £37.00
7B5B StarTech.com Vented 1U Rack Shelf - 7in In Stock £24.38
7B5B StarTech.com 1U Rack Shelf - 10in In Stock £25.16
7B5B StarTech.com Vented 1U Rack Shelf - 16 in. In Stock £31.83
7B5B StarTech.com Vented 1U Rack Shelf - 10in In Stock £21.05
7B5B StarTech.com 10-32 Server Rack Screws and Nuts - 50 Pack - Black - TAA Co In Stock £29.04
7B5B StarTech.com 1U Server Rack Shelf - 16in. Deep - EIA/ECA-310 Compliant In Stock £39.75
7B5B StarTech.com 1U Vented Shelf 12in In Stock £34.44
7B5B StarTech.com 1U Vented Shelf 20in In Stock £56.28
7B5B StarTech.com 2U Vented Shelf 14in In Stock £62.75
7B5B StarTech.com 2-Pack 1U Rack Shelf, Vented In Stock £55.99
