StarTech.com Black ATA133 Drive Drawer with Shock Absorbers
Quicklinx: 450PWS00 Mfr#: DRW110ATABK
This high quality Removable ATA Hard Drive Drawer/Mobile Rack delivers a convenient storage solution, allowing you to quickly swap ATA66/ATA100 and ATA133 hard drives in and out of a computer without having to open the computer case.
Simply install the (included) drive bay into a 5.25in drive bay on the host computer, then mount a 3.5in ATA HDD in the (removable) caddy. Connecting the ATA hard drive to the computer is as easy as inserting the caddy into the drive bay, which can be locked to prevent unauthorized removal of the installed ATA drive.
A practical, time-saving storage solution, the drive drawer/mobile rack features front panel LED indicators that continuously display the operating status of the installed drive.
A suitable solution for large volume drives, the HDD drawer supports ATA66/ATA100 and ATA133 hard drives with a capacity of up to 750GB, allowing you to swap in large amounts of data in a matter of seconds.
The drive caddy features a rear panel ball-bearing fan that helps keep the enclosed drive cool, in turn helping to optimize operation while preserving drive lifespan. To prevent damage to the hard drive(s) while being transferred in and out of the computer, the drive caddy features shock absorbers and rubber cushioning that help limit vibration/shock to the drive.
A dependable, long-lasting storage solution, the drive drawer features highly durable construction, with a 3K insertion rating.
StarTech.com Black 3.5in IDE Hard Drive Mobile Rack for 5.25in Bay w/ fan - storage mobile rack
Storage mobile rack
Expansion Bays
1 x internal - 3.5"
Compatible Bay
1 5.25" x 1/2H
Hard Drive Form Factor Compatibility
3.5"
Product Material
Plastic
14.8 cm x 22 cm x 4.1 cm
0.5 kg
Storage mobile rack
3.5"
Product Material
Plastic
Storage Controller
No CPU
Bays
1 x internal - 3.5"
1 x ATA-133 - 40 PIN IDC
1 storage - ATA-133 - 40 PIN IDC
Compatible Bay
1 x external 5.25" x 1/2H
Mounting Kit
Included
14.8 cm
22 cm
4.1 cm
0.5 kg
