StarTech.com Bi-Directional SATA IDE Adapter Converter
Quicklinx: 6LCPWS00 Mfr#: PATA2SATA3
Hurry, only 1 left in stock!
£12.21 ex VAT
£14.65 inc VAT
The PATA2SATA3 is a bi-directional SATA IDE adapter/converter that lets you connect a Serial ATA drive to a legacy IDE port, or an IDE drive to a SATA motherboard port.
A cost-effective solution for upgrading existing IDE systems to support SATA hard drives or optical drives, the SATA/IDE adapter eliminates the expense of having to purchase a controller card while saving the expansion slot that would be required for card installation.
In addition to SATA hard drive installation, the adapter can be reversed in order to connect older IDE drives to a newer SATA-enabled motherboard, making it easy to retrieve old files from a previous system.
StarTech Advantage
  • A single, versatile adapter can be used to connect an IDE device to a SATA motherboard or vice-versa without any drivers or software installation
  • Supports not only hard drives, but CD/DVD optical drives as well
  • Backed by a StarTech.com 1 year warranty and free lifetime technical support
StarTech.com SATA IDE Adapter - SATA IDE Adapter - Bi-Directional - IDE to SATA Adapter (PATA2SATA3) - storage controller - SATA 1.5Gb/s - Ultra ATA/133
Storage controller
Bus Type
Ultra ATA/133
SATA 1.5Gb/s
Data Transfer Rate
1.5 Gbit/s
Supported Devices
Hard drive, CD drive, DVD drive
Channel Qty
1
Max Storage Devices Qty
1
Product Material
Plastic
5 cm x 6.1 cm x 1.1 cm
170 g
Storage controller
Host Bus
Ultra ATA/133
Product Material
Plastic
Storage Controller
SATA 1.5Gb/s
Data Transfer Rate
1.5 Gbit/s
Supported Devices
Channel Qty
1
1
2 x SATA 1.5Gb/s - SATA
1 storage - IDE - 40 PIN IDC
1 x Serial ATA cable - internal
RoHS
5 cm
6.1 cm
1.1 cm
170 g
70 °C
6LCP StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £4.60
6LCP StarTech.com 24" Serial ATA Cable In Stock £5.26
6LCP StarTech.com 18" Serial ATA Cable w/R Angle In Stock £5.00
6LCP StarTech.com 18in SATA Serial ATA Data and Power Combo Cable In Stock £6.00
6LCP StarTech.com 18in SATA Serial ATA Cable In Stock £4.42
6LCP StarTech.com 36in SATA Serial ATA Cable In Stock £5.68
6LCP StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable In Stock £5.36
6LCP StarTech.com Bi-Directional SATA IDE Adapter Converter In Stock £12.21
6LCP StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £19.99
