Connect and position SATA drives easily - designed for larger cases. The SATA36 Serial ATA Cable features two 7-pin data receptacles and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
- StarTech.com 36in SATA Serial ATA Cable - SATA cable - Serial ATA 150 - SATA (F) to SATA (F) - 3 ft - red - SATA36 - SATA cable - 0.9 m
- SATA cable
- Interface Speed
- Serial ATA 150
- Length
- 0.9 m
- Connector
- 7 pin Serial ATA - female
- Connector (Second End)
- Red
- Limited lifetime warranty
- Designed For
- P/N: 10P6G-PCIE-SATA-CARD, 25SAT35HDD, 2P6G-PCIE-SATA-CARD, 4P6G-PCIE-SATA-CARD, 6P6G-PCIE-SATA-CARD, BRACKET25SAT, CFAST2SAT25, IDE2SAT25, PATA2SATA3, PEXSAT32, PEXSATA22I, S25SLOTR, SAT2MSAT25, SATABAY5BK, SATBP125VP, SATSASBAY3BK, USB2SATAIDE, USB3SSATAIDE
- Storage Cable Type
- SATA cable
- Interface Speed
- Serial ATA 150
- Length
- 0.9 m
- Red
- Connector
- Designed For
StarTech.com 18" Serial ATA Cable w/R Angle | In Stock | £5.00 |
StarTech.com 36in SATA Serial ATA Cable | In Stock | £5.70 |
