The PATA2SATA3 is a bi-directional SATA IDE adapter/converter that lets you connect a Serial ATA drive to a legacy IDE port, or an IDE drive to a SATA motherboard port.
A cost-effective solution for upgrading existing IDE systems to support SATA hard drives or optical drives, the SATA/IDE adapter eliminates the expense of having to purchase a controller card while saving the expansion slot that would be required for card installation.
In addition to SATA hard drive installation, the adapter can be reversed in order to connect older IDE drives to a newer SATA-enabled motherboard, making it easy to retrieve old files from a previous system.
StarTech Advantage
- A single, versatile adapter can be used to connect an IDE device to a SATA motherboard or vice-versa without any drivers or software installation
- Supports not only hard drives, but CD/DVD optical drives as well
- Backed by a StarTech.com 1 year warranty and free lifetime technical support
Reliable Data Transfer
The storage controller supports a data transfer rate of 1.5 Gbit/s, ensuring efficient communication between connected devices. -
Flexible Compatibility
This adapter is compatible with various storage devices such as hard drives, CD drives, and DVD drives, allowing users to utilize existing hardware seamlessly. -
Robust Design
Constructed from plastic, this adapter is built to withstand a range of operating temperatures, making it suitable for use in various environments. -
Easy Installation
With a Plug-and-Play design, this adapter allows for quick and straightforward installation, minimizing downtime during upgrades or repairs.
- StarTech.com SATA IDE Adapter - SATA IDE Adapter - Bi-Directional - IDE to SATA Adapter (PATA2SATA3) - storage controller - SATA 1.5Gb/s - Ultra ATA/133
- Storage controller
- Bus Type
- Ultra ATA/133
- Black
- Interface
- SATA 1.5Gb/s
- Data Transfer Rate
- 1.5 Gbit/s
- Supported Devices
- Hard drive, CD drive, DVD drive
- Channel Qty
- 1
- Max Storage Devices Qty
- 1
- Product Material
- Plastic
- 5 cm x 6.1 cm x 1.1 cm
- 170 g
- 2-year warranty
- Host Bus
- Ultra ATA/133
- Product Material
- Plastic
- Black
Storage Controller
- Interface
- SATA 1.5Gb/s
- 1.5 Gbit/s
- Supported Devices
- Channel Qty
- 1
- 1
- 2 x SATA 1.5Gb/s - SATA
- Connections
- 1 storage - IDE - 40 PIN IDC
- Cables Included
- 1 x Serial ATA cable - internal
- RoHS
- Limited warranty - 2 years
- 5 cm
- 6.1 cm
- 1.1 cm
- 170 g
- 0 °C
- 70 °C
StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter | In Stock | £5.06 |
StarTech.com 24" Serial ATA Cable | In Stock | £5.28 |
StarTech.com 18" Serial ATA Cable w/R Angle | In Stock | £5.00 |
StarTech.com 18in SATA Serial ATA Data and Power Combo Cable | In Stock | £5.78 |
StarTech.com 18in SATA Serial ATA Cable | In Stock | £2.45 |
StarTech.com 36in SATA Serial ATA Cable | In Stock | £5.70 |
StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable | In Stock | £5.50 |
StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks | In Stock | £19.65 |
