Mount your display on your desk surface or through a grommet, with spring-assisted height adjustment and cable management. This slim, articulating monitor arm lets you mount a flat-panel display on your desk or table, with dynamic adjustments that make it easy to position your monitor for the perfect viewing angle and optimal comfort. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
The versatile monitor arm lets you extend, tilt, pan, swivel and pivot your display with a full range of motion across multiple axes, and features spring-assisted height adjustments for effortless positioning. For viewing longer pages or blocks of code without having to scroll down your screen, the LCD arm also supports simple landscape-to-portrait display rotation.
With a stylish, slim design that looks great and takes up only a small amount of desk space, the monitor arm gives you the flexibility to locate your display as needed while reclaiming valuable workspace on your desk. Mounting your display above the desk surface enables you to adjust your display height, position and viewing angles easily, for an ergonomic work environment.
Supporting 12 - 26" displays up to a maximum weight capacity of 15lbs (7kg), the monitor-mounting arm holds your display with ease, and integrates a cable management channel to keep things neat. For added installation flexibility, the included mounting hardware can either clamp to the side of your desk / table or mount through a grommet hole.
- StarTech.com Desk Clamp Monitor Mount - Adjustable - Supports Monitors 12" to 34" - Full Motion Slim VESA Mount Monitor Arm - Desk & Grommet Clamp -Black (ARMSLIM) - mounting kit - adjustable arm - for LCD display - black
- Product Type
- Mounting kit (adjustable arm) - desk-mountable
- Tilt
- -65° to 90°
- Swivel
- 180°
- Adjustments
- Pan, tilt
- 3.2 kg
- Recommended Use
- LCD display
- Recommended Display Size
- 12"-34"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 7 kg
- Material
- Plastic, steel
- Black
- 2-year warranty
- Designed For
- P/N: ARMSTS, ARMSTSLG, STSCART
- 3.2 kg
- Material
- Plastic, steel
- Black
AV Furniture
- Mounting kit
- Design
- Adjustable arm
- Recommended Use
- LCD display
- Placing / Mounting
- Desk-mountable
- Cable Management
- Integrated cable management
- 12"-34"
- Tilt
- -65° to 90°
- Swivel
- 180°
- Adjustments
- Pan, tilt
- Max Load Weight
- 7 kg
- Adjustable height, portrait to landscape movement, swivel adjustment, pivot
- Limited warranty - 2 years
- Designed For
StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 | In Stock | £85.40 |
StarTech.com Height Adjustable Monitor Arm - Grommet / Desk Mount with Cable Hook | In Stock | £69.07 |
StarTech.com Desktop Monitor Stand with Cable Hook - Mounting Kit | In Stock | £90.09 |
StarTech.com Articulating Monitor Arm | In Stock | £124.46 |
StarTech.com Sit-to-Stand Workstation | In Stock | £279.02 |
StarTech.com Monitor and Laptop Arm | In Stock | £101.33 |
StarTech.com USB-C Multifunction Adapter | In Stock | £52.01 |
StarTech.com Thin Client Mount - VESA | In Stock | £24.79 |
StarTech.com Under Desk Keyboard Tray | In Stock | £60.89 |
StarTech.com Desk Mount Monitor Arm | In Stock | £69.78 |
