StarTech.com Under Desk Keyboard Tray
Quicklinx: DHNXWS00 Mfr#: KBTRAYADJ
13 In Stock
£53.36 ex VAT
£64.03 inc VAT
Work in greater comfort with this easily adjustable ergonomic keyboard tray. This under-desk keyboard tray adds comfort to your work day, by easing the strain on your wrists and arms. It also frees up valuable desk space.
The spacious design of the keyboard tray, 26.4" (670 mm) wide x 10" (255 mm) depth, gives you ample room for your keyboard and mouse. Its quality construction, with a weight capacity of 4.4 lb. (2 kg), provides a stable platform that doesn't shake when you're typing.
The ergonomic design of this adjustable keyboard tray, including a built-in wrist rest, provides a wide range of movement to reduce discomfort and work-related injuries. It lets you adjust your position for comfortable arm and shoulder postures while typing, helping you be more productive throughout your work day.
Easily adjust your keyboard tray down or up, with a height adjustment range of up to 6.7" (170 mm). You can slide the keyboard tray in or out from your desk to find your ideal position. Turn the knob at the side to tilt the keyboard tray +15° / -15° for added comfort. You can even adjust your keyboard tray to the left or right, with +20° / -20° swivel.
The under-desk keyboard tray clears space on your desktop. The track-mounted design lets you slide it under your desk when not in use, with an extension range of up to 12.6" (320 mm).
  • Adjustable Design
    The keyboard tray features an adjustable width to accommodate different desk configurations and user requirements.
  • Ergonomic Benefits
    Tilt adjustment from -15° to +15° and pivoting capabilities help reduce strain on wrists and promote a comfortable typing experience.
  • Organized Workspace
    Integrated cable management keeps cords organized, creating a clean and efficient work area.
  • Easy Installation Components
    Included mounting arm and screws ensure a straightforward setup process without the need for additional tools.
  • Sturdy Construction
    Crafted from durable plastic and steel, this tray can support devices weighing up to 2 kg, ensuring reliable performance.
StarTech.com Under Desk-Mount Keyboard Tray - 26.4” Wide - Adjustable - Ergonomic Slide-Out Keyboard Shelf with Tilt and Swivel (KBTRAYADJ) - keyboard drawer
Keyboard drawer
Package Content
Tray, sliding rail, mounting arm, 4 mounting screws, 4 rail screws, 4 tray screws, 4 screw covers, 2 rubber pads
Placing / Mounting
Under-desk mountable
Product Material
Steel, plastic
78.2 cm x 67 cm x 21.5 cm
5 kg
P/N: ARMBARDUO, ARMBARDUOV, ARMBARTRIO2, ARMCBCL, ARMDUAL, ARMDUAL30, ARMDUALSS, ARMDUALV, ARMPIVOT, ARMPIVOTB, ARMPIVOTE, ARMPIVOTHD, ARMPIVOTV2, ARMPIVSTND, ARMSLIM, ARMSLIMDUO, ARMTRIO, ARMUNONB, LTRISERP, MONSTADJD, MONSTADJDL, MONSTADQI
Keyboard drawer
Package Content
Placing / Mounting
Product Material
Steel, plastic
78.2 cm
67 cm
21.5 cm
5 kg
5.4 kg
Adjustable, integrated wrist rest, integrated cable management, pivoting, tilt adjustment -15° to +15°, max load 2 kg
