StarTech.com 95mm CPU Cooler Fan with Heatsink for Socket LGA1156/1155 with PWM
Quicklinx: 7W8FWS00 Mfr#: FAN1156PWM
Type: CPU Cooler
Hurry, only 3 left in stock!
£15.24 ex VAT
£18.28 inc VAT
The FAN1156PWM CPU Cooler with PWM Cooling Fan for Socket LGA1156/1155 systems provides reliable and efficient cooling for compatible Intel Core i3/i5/i7 CPUs. With Pulse Width Modulation (PWM) technology, the fan speed can be dynamically controlled by the motherboard, so the fan runs at a speed that suits the operating conditions - lowering power consumption and fan noise when the system is idle, and delivering maximum cooling under full load conditions.
StarTech.com 95mm CPU Cooler Fan with Heatsink for Socket LGA1156/1155 - w/ Pulse Width Modulation (PWM) (FAN1156PWM) - processor cooler
Processor cooler
Compatibility
LGA1156 Socket, LGA1155 Socket
Heatsink Material
Aluminium
Fan Diameter
95 mm
Fan Height
25 mm
Fan Bearing
Ever Lubricate bearing
Rotation Speed
1000-3000 rpm
Air Flow
65.6 cfm
Noise Level
33 dBA
Power Connector
4-pin fan connector
9.5 cm x 9.5 cm x 4.5 cm
297 g
Processor cooler
9.5 cm
9.5 cm
4.5 cm
297 g
Heatsink & Fan
Compatible With
Processor Compatibility
Core i3 , Core i7 , Core i5
Heatsink Material
Aluminium
Heatsink Dimensions
95 mm x 95 mm x 20 mm
Fan Diameter
95 mm
Fan Height
25 mm
Fan Bearing
Rotation Speed
1000-3000 rpm
Air Flow
65.6 cfm
Noise Level
33 dBA
Power Connector
4-pin fan connector
MTBF
40,000 hour(s)
RoHS
Limited warranty: - 2 years
-20 °C
70 °C
7W8F StarTech.com 1.5g Metal Oxide Thermal CPU Paste Compound Tube for Heatsink In Stock £4.31
7W8F StarTech.com 12in 4 Pin Fan Power Splitter Cable - F/M In Stock £5.88
7W8F StarTech.com 20g Tube CPU Thermal Paste Grease Compound for Heatsinks In Stock £5.25
Type: CPU Cooler
