Connect your VGA display to a DVI-I source. The DVIVGAMF8IN DVI to VGA cable (8-inch) is used to adapt a DVI male connector to a VGA female connector and enables you to connect a flat panel display to a PC or MAC computer with DVI-I output.
The VGA female connection added by the dongle is situated approximately 8 inches away from the DVI output connection, which lessens strain on and prevents damage to the DVI connector while reducing the potential of blocking other available ports.
The DVI male to VGA female adapter is constructed of high quality materials to ensure dependability.
- StarTech.com 8in DVI to VGA Cable Adapter - DVI-I Male to VGA Female Dongle Adapter (DVIVGAMF8IN) - VGA adapter - 20 cm
- VGA adapter
- Technology
- Shielded
- Thumbscrews
- Length
- 20 cm
- Connector
- DVI-I - male
- Connector (Second End)
- HD-15 (VGA) - female
- RoHS
- Black
- Limited lifetime warranty
- VGA adapter
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Thumbscrews
- Length
- 20 cm
- Black
- Connector
- 24+5 pin combined DVI - male
- 15 pin HD D-Sub (HD-15) - female
- RoHS
StarTech.com DVI to VGA Cable Adapter - M/F | In Stock | £5.42 |
StarTech.com DVI to VGA Cable Adapter - Black - M/F | In Stock | £6.13 |
StarTech.com 8in DVI to VGA Cable Adapter - DVI-I Male to VGA Female | In Stock | £7.53 |
