Add a variable speed, PWM-controlled cooling fan to a computer case. The FAN8025PWM 80mm PWM case fan adds an efficient air cooling solution to computer cases or other enclosures, to keep components running optimally.
With Pulse Width Modulation (PWM) technology, the fan speed can be dynamically controlled by the motherboard, so the fan runs at a speed that suits the operating conditions - lowering power consumption and fan noise when the system is idle, and delivering maximum cooling under full load conditions.
Efficient airflow
The fan provides airflow rates between 9.74 and 25 cfm, supporting effective cooling for various case setups. -
Quiet performance
Operating at noise levels of 10 to 28 dBA, this fan maintains a peaceful computing environment while ensuring adequate cooling. -
Robust temperature range
With a minimum operating temperature of -10°C and a maximum of 70°C, this fan is designed to function effectively in diverse thermal conditions. -
Flexible connectivity
The included Y-Split cable allows for connecting multiple fans or provides versatility in setup options. -
Bearing technology
The Ever Lubricate bearing enhances the fan's lifespan and ensures smooth operation under continuous use.
- StarTech.com 80x25mm Computer Case Fan with PWM - Pulse Width Modulation Connector - computer cooling Fan - 80mm Fan - pwm Fan (FAN8025PWM) - case fan
- Product Type
- Case fan
- Package Content
- Y-Split cable
- Black
- Fan Diameter
- 80 mm
- Fan Height
- 25 mm
- Fan Bearing
- Ever Lubricate bearing
- Rotation Speed
- 800-2500 rpm
- Air Flow
- 9.74-25 cfm
- Noise Level
- 10 - 28 dBA
- Power Connector
- 4-pin fan connector, 4 pin Molex connector
- 8 cm x 8 cm x 2.5 cm
- 86 g
- 2-year warranty
- Product Type
- Case fan
- Package Content
- Y-Split cable
- 8 cm
- 8 cm
- 2.5 cm
- 86 g
- Black
Heatsink & Fan
- Fan Diameter
- 80 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rotation Speed
- 800-2500 rpm
- Air Flow
- 9.74-25 cfm
- Noise Level
- 10 - 28 dBA
- Power Connector
- RoHS
- Limited warranty: - 2 years
- -10 °C
- 70 °C
StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan with LP4 Connector | In Stock | £5.94 |
StarTech.com Mounting PC Case Fan Screws - 50 Pack | In Stock | £3.01 |
StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan with TX3 Connector | In Stock | £5.35 |
StarTech.com 12in 4 Pin Fan Power Splitter Cable - F/M | In Stock | £6.34 |
StarTech.com 120x25mm Computer Case Fan with PWM – Pulse Width Modulation Connector | In Stock | £7.56 |
StarTech.com 80x25mm Computer Case Fan with PWM – Pulse Width Modulation Connector | In Stock | £6.48 |
