The PCI8S950LP PCI Serial Card (16950 UART) lets you turn a single low profile PCI slot into eight RS232 (DB9) serial connections. The unique design of the serial card and included break out cable feature a VHDCI (Very High Density Cable Interconnect) connector, enabling the addition of 8 serial interfaces while only using a single expansion slot. The 8-port serial adapter card is compatible with a broad range of operating systems, including Windows 2000/XP/2003/Vista/7, as well as Linux Kernel 2.4.x and up.
- StarTech.com 8 Port Low Profile RS232 PCI Serial Card with 16950 UART - serial adapter - PCI-X - RS-232 x 8
- Serial adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI-X
- Ports
- RS-232 x 8
- 5 cm x 12.6 cm x 2 cm
- 60 g
- Cabling Type
- Serial RS-232
- Limited lifetime warranty
- Serial adapter
- Form Factor
- PCI-X
- Ports
- RS-232 x 8
- Connectivity Technology
- Wired
- Cabling Type
- Serial RS-232
- 8 x RS-232 - 9 pin D-Sub (DB-9)
- Compatible Slots
- 1 x PCI-X
- WHQL, FCC, RoHS
- Software Included
- Drivers & Utilities
- 5 cm
- 12.6 cm
- 2 cm
- 60 g
- Limited warranty - lifetime
- -20 °C
- 85 °C
- 5 - 85%
