StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD
Quicklinx: 7P3DWS00 Mfr#: SV831DUSBU
Type: KVM switch
Connectivity: KVM
Ports: 8
£284.45 ex VAT
£341.34 inc VAT
This 8 Port USB KVM Switch offers a dependable computer management tool that allows you to control up to 8 USB-connected computers from one keyboard, mouse and monitor.
The KVM switch offers maximum control, allowing you to switch computers using hotkey commands or front panel push-buttons, and offers the added configurability and convenience of an On Screen Display.
A suitable addition to server room operations, the 8 port switch can be rackmounted into 1U of cabinet space, and can be cascaded with multiple KVM switches to deliver control of up to 64 computers from this single switch.
StarTech.com 8-Port USB KVM Swith with OSD - TAA Compliant - 1U Rack Mountable VGA KVM Switch (SV831DUSBU) - KVM switch - 8 ports
KVM switch - 8 ports - cascadable
Enclosure Type
1U
Subtype
KVM
Ports
8 x KVM port(s)
KVM Users Qty
1 local user
On-Screen Display
AC 120/230 V
54 cm x 18 cm x 4.5 cm
2.9 kg
3-year warranty
P/N: 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12U, 4POSTRACK25U, RK1233BKM, RK1833BKM, RK2433BKM, RK2537BKM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK8OD, RK960CP, RKCONS1701, RKCONS17HD, RKCONS1901, RKCONS1908K, RKCONS1916K, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12, SVA12M2NEUA, SVA12M5NA
Enclosure Type
Desktop 1U
Subtype
KVM
Ports
8 x KVM port(s)
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1440
On-Screen Display
Status Indicators
Port status, power
Display / video / USB: 8 x 15 pin HD D-Sub (HD-15) , 1 x VGA HD-15 , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A
External power adapter
AC 120/230 V
FCC, RoHS
54 cm
18 cm
4.5 cm
2.9 kg
Limited warranty - 3 years
P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, IM12D1500P, RACKCOND1701, RACKCOND17HD, RACKCONV1701, RK1233BKM, RK1236BKF, RK12OD, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK8OD, RK960CP, RKCONS1701, RKCONS17HD, RKCONS1901, RKCONS1908K, RKCONS1916K, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12, SVA12M2NEUA, SVA12M5NA, SVECONUS10, SVECONUS15, SVECONUS6, SVUSBVGA10, SVUSBVGA6
7P3D StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable In Stock £9.85
7P3D StarTech.com 4 Port Professional VGA USB KVM Switch with Hub In Stock £86.26
7P3D StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £542.00
7P3D StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £284.45
7P3D StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £317.76
7P3D StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £633.38
7P3D StarTech.com 6 ft Ultra-Thin USB VGA 2-in-1 KVM Cable In Stock £7.54
7P3D StarTech.com DC Power Adapter - 12V, 2A In Stock £11.96
7P3D StarTech.com DC Power Adapter - 12V, 5A In Stock £41.02
7P3D StarTech.com 8-Port DisplayPort KVM Switch In Stock £419.56
Type: KVM switch
Connectivity: KVM
Ports: 8
