The SV1631DUSBUK 16 Port 1U Rack Mount USB KVM Switch Kit with OSD and Cables offers a well-appointed KVM switch that includes all of the cables and accessories required to connect to 16 servers or PCs right out of the box, making setup convenient and simple.
The USB KVM delivers a dependable computer management tool that allows you to control up to 16 USB-connected computers from a single keyboard, mouse and display, providing maximum control through hotkey command-based switching or front panel push-buttons, with the added configurability and convenience of an On-Screen Display.
A suitable addition to server room operations, the 16-port switch can be rackmounted into 1U of cabinet space and can be cascaded with multiple KVM switches to enable control of up to 136 computers from this single switch.
Versatile Connectivity
This KVM switch supports both USB connections for keyboards and mice, as well as VGA for video, allowing for compatibility with a wide range of devices. -
High Performance
With a maximum video resolution of 1920 x 1440 and a refresh rate of 60 Hz, users can expect visuals for all applications. -
Reliable Operation
Designed to work in various environmental conditions, this KVM switch operates effectively in temperatures ranging from 5°C to 40°C and can handle humidity levels of 0 to 80%. -
Easy Management
The On-Screen Display feature simplifies the process of switching between devices, allowing users to manage multiple systems with ease. -
Compliant and Safe
Meets FCC and RoHS standards to ensure environmental safety, making it a responsible choice for both personal and professional use.
- StarTech.com 16 Port Rackmount USB KVM Switch Kit with OSD and Cables - 1U (SV1631DUSBUK) - KVM switch - 16 ports
- KVM switch - 16 ports - cascadable
- Enclosure Type
- 1U
- Subtype
- KVM
- Ports
- 16 x KVM port(s)
- KVM Users Qty
- 1 local user
- On-Screen Display
- Power
- AC 120/230 V
- 54 cm x 18 cm x 4.5 cm
- 3.1 kg
- Black
- 3-year warranty
- Designed For
- P/N: 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKHD, RACKCOND17HD, RK1233BKM, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RKCONS1701, RKCONS17HD, SVA9M2NEUA, SVUSBVGA10, SVUSBVGA6
- Enclosure Type
- Desktop 1U
- Subtype
- KVM
- Ports
- 16 x KVM port(s)
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 1920 x 1440 @ 60 Hz
- On-Screen Display
- Status Indicators
- Port status, power
- 16 x KVM HD-15 , 1 x VGA HD-15 , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Black
- Cables Included
- 16 x keyboard / mouse / video cable - 1.8 m
- Rack Mounting Kit
- Included
- FCC, RoHS
- 54 cm
- 18 cm
- 4.5 cm
- 3.1 kg
- Limited warranty - 3 years
- 5 °C
- 40 °C
- 0 - 80%
- Designed For
- P/N: 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RACKCOND17HD, RK1233BKM, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RKCONS1701, RKCONS17HD, SVA9M2NEUA, SVECONUS10, SVECONUS15, SVECONUS6, SVUSBVGA10, SVUSBVGA6
StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable | In Stock | £9.47 |
StarTech.com 4 Port Professional VGA USB KVM Switch with Hub | In Stock | £83.88 |
StarTech.com 1U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £36.68 |
StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket | In Stock | £35.52 |
StarTech.com Long Range USB VGA KVM Console Extender over Cat5 UTP - 1000 ft | In Stock | £298.22 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.37 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.56 |
StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £2.97 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.97 |
StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £464.07 |
StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £527.07 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £280.59 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £317.20 |
StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch | In Stock | £543.36 |
StarTech.com 6 ft Ultra-Thin USB VGA 2-in-1 KVM Cable | In Stock | £7.40 |
StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £6.71 |
StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F | In Stock | £7.11 |
StarTech.com 2-port Dual VGA KVM Switch | In Stock | £67.05 |
StarTech.com DC Power Adapter - 9V, 2A | In Stock | £12.21 |
StarTech.com 8-Port DisplayPort KVM Switch | In Stock | £408.00 |
StarTech.com 8-Port HDMI KVM Switch | In Stock | £502.49 |
