StarTech.com 8-Port (4 PoE+) GbE Switch
Quicklinx: CWB9WS00 Mfr#: IES81GPOEW
Type: Gigabit Ethernet
Ports: 8
Data Transfer Rate: [N/A]
Managed: Yes
POE: PoE+
10 In Stock
£217.43 ex VAT
£260.91 inc VAT
Connect up to 8 different GbE (4 PoE+) devices, using this IP30 industrial Ethernet switch with intelligent Layer 2 management. Easily deploy or scale your network with this Gigabit Ethernet switch, by adding eight copper Gigabit Ethernet connections, including four PoE+ ports. This IP30 industrial network switch provides intelligent Layer 2 management. Its rugged, compact design and wall-mount option with front access make it ideal for demanding applications, even where space is limited.
This Gigabit Ethernet switch lets you expand your network by connecting up to eight RJ45 devices (four PoE+). The 8-Port switch enables up to eight users to share files and devices, such as printers and scanners, over a LAN connection, by enhancing your existing network capacity with additional ports.
The switch gives you the freedom to place your equipment in locations where power outlets are not available, with support for Power over Ethernet Plus. The network switch provides abundant PoE power, with up to 30 watts for each PoE port (120W budget).
With its compact design, you can wall-mount the Gigabit switch to provide convenient front access to ports and indicators. It's ideal for a wide range of applications, including tight installation areas with significant electromagnetic interference, such as control cabinets and panels. The network switch is also DIN-rail mountable.
The switch delivers efficient and stable performance, with Layer 2 management capabilities. This lets you control packet traffic on a busy network, and customize your settings to achieve optimal network performance, offering improved efficiency and reliability.
This rugged network switch features an IP30-rated metal housing and extended temperature range of -40°C to 75°C, which makes it ideal for a wide range of operating conditions. The sturdy metal enclosure offers durability, even in harsh industrial environments.
With support for 10/100/1000Mbps transfer speeds, this managed switch supports full/half-duplex auto-negotiation, jumbo frames and auto MDI/MDIX operation. This lets you connect your network devices quickly and easily, with little to no configuration required.
To help prevent any unnecessary downtime, the switch features redundant 12-58V DC terminal block power inputs, which ensures seamless operation in the event of power dips or failures.
StarTech.com Industrial 8 Port Gigabit PoE Switch, 4 x PoE+ 30W, Power Over Ethernet, Hardened GbE Layer/L2 Managed Switch, Rugged High Power Gigabit Network Switch IP-30/-40C to +75C - Managed Network Switch (IES81GPOEW) - switch - 8 ports - Managed
Switch - 8 ports - Managed
Subtype
Gigabit Ethernet
Ports
4 x 10/100/1000 + 4 x 10/100/1000 (PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
120 W
Performance
Data transfer rate: 2 Gbps
Buffer capacity (MB): 0.512
Jumbo Frame Support
9KB
Routing Protocol
IGMP, MLD
Remote Management Protocol
HTTP
Layer 2 switching, IPv6 support, full duplex mode, wall mountable, TFTP support, tagged VLAN, 6KV ESD Protector, 802.1x authentication, ICMP, 6KV EFT protector
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at
DC 12 - 48 V
14.8 cm x 13.4 cm x 2.5 cm
625 g
Enclosure Type
Wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
120 W
Performance
Jumbo Frame Support
9KB
Routing Protocol
IGMP, MLD
HTTP
Status Indicators
Power, PoE
4 x 1000Base-T RJ-45 , 4 x 1000Base-T RJ-45 PoE+ - 30 W , 1 x terminal block
DC 12 - 48 V
4 magnets, DIN-rail mounting kit, 4 x screws, attaching pins, locking pins, 4 washers, 8 RJ45 dust caps
MTBF
>100,000 hours
FCC, RoHS, WEEE, IP30, RCM
14.8 cm
13.4 cm
2.5 cm
625 g
-40 °C
75 °C
5 - 95% (non-condensing)
CWB9 StarTech.com 8-Port (4 PoE+) GbE Switch In Stock £217.43
CWB9 StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports In Stock £338.20
CWB9 StarTech.com 4-Port PoE+/PoE++ Injector 95W In Stock £259.37
Ports: 8
Managed: Yes
POE: PoE+
