StarTech.com 4-Port PoE+/PoE++ Injector 95W
Quicklinx: HJFGWS00 Mfr#: AS445C-POE-INJECTOR
Type: [N/A]
10 In Stock
£251.11 ex VAT
£301.33 inc VAT
This 4-Port Multi-Gigabit PoE++ Injector Hub serves as Power Sourcing Equipment (PSE) and enables multigigabit speeds of 5Gbps, 2.5Gbps, 1Gbps, 100Mbps, and 10Mbps across four Ethernet ports. This mid/end-span injector is capable of transmitting network data and power up to 328ft (100m) for remote installations. The PoE, PoE+, PoE++ compatibility and selectable power output ensure seamless compatibility with Powered Devices (PD). The TAA-compliant injector includes a Universal Power Adapter for different regions (NA/JP, EU, UK, and ANZ).
  • Versatile PoE Injector
    Multiport PoE Injector supports the IEEE 802.3af, 802.3at, and 802.3bt (Type 3 and Type 4) standards for Power Sourcing Equipment (PSE), delivering up to 52V DC and 95Watts. This flexibility eliminates the need for a separate power source for remote networked devices such as IP cameras, access control devices, remote kiosks (POSs), wireless access points, PoE lighting, and digital signage. Experience streamlined cable management with all network cables routed from one side of the unit for a clean and organized setup.
  • Flexible Power Options
    Tailor the power output to the specific needs of the device using the Power Output Switch. The options include 90W, 95W PoH, or legacy 60W (for UPoE/UPoE+) for all the ports on the PoE Injector Adapter. The Level-4 ESD protection (15kV air and 8kV contact) enhances device safety and reduces EMI for stable operation, minimizing the risk of downtime and hardware failures.
  • Increased Network Speeds
    The unmanaged PoE Injector with NBASE-T technology provides access to an increased bandwidth up to 5Gbps, significantly reducing network slowdowns during data-intensive applications such as streaming high-definition video feeds, high-speed Internet, access local network resources, online or local network backups, and FTP access.
StarTech.com 4-Port Multi-Gigabit PoE++ Injector, 5/2.5G Ethernet (NBASE-T), PoE/PoE+/PoE++ (802.3af/802.3at/802.3bt), 160Watts Power Budget, Wall/DIN Rail Mountable - Unmanaged, For IP Cameras/Wireless APs/POSs (AS445C-POE-INJECTOR) - PoE injector - 160 Watt - TAA Compliant
PoE injector - DIN rail mountable / wall
Power Over Ethernet (PoE)
PoE++
278 g
Output Voltage
DC 52 V
Power Capacity
160 Watt
Output connectors
4 x RJ-45
Power adapter, DIN rail mounting kit
TAA Compliant
TAA Compliant
7 cm x 9.4 cm x 3.9 cm
PoE++ (IEEE 802.3bt)
4 x RJ-45
Output Voltage
DC 52 V
Power Capacity
160 Watt
4 x 1/2.5/5 Gigabit LAN (PoE++) - RJ-45 , 4 x 1/2.5/5 Gigabit LAN - RJ-45
Wake on LAN, auto MDIX support, rugged metal housing, 100 m maximum cable length, supports 9K jumbo frames, LED indicators, auto negotiating, 8 kV ESD protection (Contact), 15 kV ESD protection (Air)
IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3at, IEEE 802.3bz, IEEE 802.3bt, IEC 61000-4-2, DOC, WEEE
TAA Compliant
50 °C
5 - 95% RH (non-condensing)
7 cm
9.4 cm
3.9 cm
278 g
Shipping Width
17 cm
Shipping Depth
30 cm
Shipping Height
9 cm
Shipping Weight
1.7 kg
HJFG StarTech.com 100 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £31.89
HJFG StarTech.com Fiber to RJ45 Media Converter In Stock £112.53
Type: [N/A]
